i need more power out of my 93 delso.. NA power only
Old Jan 23, 2006 | 03:11 AM
wooso's Avatar
Default i need more power out of my 93 delso.. NA power only
hi all..
i have a 93 delso.. b16a its making 107kw at the wheel with no internals..
i dont want to spend to much... under $3000..
i have put in a cold air intake, exhaust and spoon ecu..
thank you..
that was my frist time posting sorry..
Modified by wooso at 2:27 AM 1/24/2006
Old Jan 23, 2006 | 03:58 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: i need more power out of my 93 delso.. NA power only (wooso)
What motor?
Old Jan 23, 2006 | 06:47 AM
Everyones Hero's Avatar
Default Re: i need more power out of my 93 delso.. NA power only (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">What motor?</TD></TR></TABLE>
Dude, you've got to get rid of that avatar.
How much is too much?
You can get an intake, cam, headers, exhaust.
Old Jan 23, 2006 | 07:16 AM
Mwsol's Avatar
Default Re: i need more power out of my 93 delso.. NA power only (Everyones Hero)
I tried that "N/A" d16 set up and that didn't work out with my butt dyno.
Assuming your 93 del sol is stock, your still running the single slam.
If you want more out of it your going to invest money any way you go.
If you are a d15, then buy a z6 head and dizzy with sensors and IM and ecu. Wire it up now you have a much better head and "VTEC."
Or, if your already a z6(si), then go ahead and order a zex 59300, some cam gear(dont know if it will help you any), basic bolt ons... IHE... Then tune it. If your still not satisfied then go with a ITB setup. Even more of pain to tune, from what i've heard, but much more air to flow then the stock plenum.
Old Jan 23, 2006 | 07:27 AM
dohcdelsol's Avatar
Default Re: i need more power out of my 93 delso.. NA power only (Mwsol)
^ agree with him.
Also, after that you might want to look into new pistons/rods that will increase comp. ratio. Then some head work ie pnp, valves/valve springs ect. if money isnt a factor
Old Jan 24, 2006 | 01:33 AM
wooso's Avatar
hi all..
thank you..
Old Jan 24, 2006 | 01:34 AM
wooso's Avatar
hi all..
thank you..
Old Jan 24, 2006 | 02:47 AM
Eaglekper0046's Avatar
Throw a set a of cams in, do a port job. Get a header, and if your feeling froggy get some CRT pistons
scorched0
Sep 23, 2007 07:04 PM
Convert
Jul 20, 2007 03:58 PM
BigaCustoms
Jan 27, 2005 10:49 AM
integrated_bob
Oct 12, 2004 06:25 PM
virginia_dude
24
Mar 23, 2004 08:32 PM
