condensation in jdm itr hids. i searched. HELP!
Old Jan 22, 2006 | 11:50 PM
Turbo(less)DB8's Avatar
Default condensation in jdm itr hids. i searched. HELP!
Ok, I just did a jdm hid conversion on my 99 db8 (well about 6 months ago). Recently it started raining a lot and the headlights have built up a ton of moisture. They're almost completely fogged up. My question is this... how do i fix this? I've been searching a ton about baking them. All I have found have been done to paint the inner housing and on civics. These headlights are waaaaaay expensive and I don't wanna screw them up. PLEASE help.
Old Jan 23, 2006 | 11:55 AM
Default Re: condensation in jdm itr hids. i searched. HELP! (Turbo(less)DB8)
no one?
Old Jan 23, 2006 | 06:42 PM
ok someone has had to have had this problem
Old Jan 25, 2006 | 12:23 PM
Rcp's Avatar
Rcp
I think you have to pop it in the oven for like 3-6 minutes so the glue will loose up. After that clean the insides and seal it up with silicone again.
Modified by Rcp at 3:21 PM 1/25/2006
Old Jan 25, 2006 | 01:09 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: (Rcp)
Yeah, I had this problem.
What I did was simply pull out all the bulbs. On the projecter, there should be a few screws that you need to remove. Once you do, you can remove the projector and you'll have a nice big hole that you can work with.
Then, shake the head light. You want to get as much water out as possible. Then use a hair dryer to blow out and evaporate the moisture in the headlight.
When I did it, I ended up with hardwater spots. So I took some Window cleaner, sprayed it in there, and swooshed it around. The use the blowdryer again.
After all that, I took some sealant and sealed the housing. Also, make sure the caps are in place and locked, the ones you need to turn to remove the bulb.
Old Jan 31, 2006 | 08:08 PM
Default Re: (carma_626)
thanks, just what i was looking for
R_Status
Apr 16, 2007 07:48 PM
Ermac
Honda S2000
Oct 14, 2005 02:05 AM
bgood7061
Oct 20, 2002 12:28 AM
the big ragu
Aug 19, 2002 02:33 PM
