wuts wrong,my lude keeps boggen?
the bogging is like when u bounce the tak of the limiter,it holds bak and boggs out.it dosnt backfire but it allways stitting out some kind of fluid like water or somtin,and when it idles it sounds like theres a puttle of water in the muffler...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BornLude702 »</TD></TR><TR><TD CLASS="quote">yes and yes.im gonna change my oil and put some water cleaner in it today.its spitting out madd water from the muffler wen i rev for some reason</TD></TR></TABLE>
water cleaner?
the water in your tailpipe is a byproduct of the catalytic converter doing its job
water cleaner?
water is not a byproduct of the catalytic converter. the water in your tailpipe comes from the moistre in the air. its called condensation. if your coil was going bad then it could limit the rpms. like if there was too much resistance in the primary coil, when the dwell time gets too short it might not be able to create a large enough magnetic field to induce "spark" in the secondary.
motormanSR
Mar 15, 2005 02:46 PM
DrRoboto
Apr 3, 2003 11:01 AM
