oil change. weard clicking sound?
Old Jan 22, 2006 | 09:28 PM
watsvtecEK's Avatar
Default oil change. weard clicking sound?
I changed my oil a few days ago, i used a pureone oil filter, and 4qts or quaker state 5-30w. It started after i changed the oil. A clicking or ticking sound from the head. What could it be? maby i should try a different oil? thanks
btw my oil level is good, just at full.
Old Jan 22, 2006 | 09:34 PM
shorto85's Avatar
Adjust your valves
Old Jan 22, 2006 | 09:57 PM
watsvtecEK's Avatar
Default Re: (shorto85)
but it didn't do it before the oil change. and before i was using some crappy shell oil.
Old Jan 22, 2006 | 10:03 PM
ZipTieGUy's Avatar
Default Re: (D 2da A9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">but it didn't do it before the oil change. and before i was using some crappy shell oil.</TD></TR></TABLE>
when you take the oil out and put oil in.. theres not enough oil on top so it clicks. after 10 minutes its all good... it doesnt click no more right? just right after the oil change? same thing happened to me
Old Jan 22, 2006 | 10:06 PM
watsvtecEK's Avatar
Default Re: (ZipTieGuy)
still doing it, seems that it got worse. and i can hear it better when it is warm, not as much when it is cold. I really didn't notice it till the day after i did it.
Modified by D 2da A9 at 1:22 PM 1/23/2006
Old Jan 23, 2006 | 12:58 AM
argetni_acura's Avatar
placebo (spelling) effect.
Old Jan 23, 2006 | 12:28 PM
watsvtecEK's Avatar
Default Re: (argetni_acura)
bump i want to know, could it be the oil? its the Quaker state high performance, or whatever. Is it just coincidental that it started right after i changed the oil?
Old Jan 23, 2006 | 12:48 PM
b20integrapower's Avatar
my valves click until the car is at operatiing temp...then it goes away...is that normal?
Old Jan 23, 2006 | 01:31 PM
teggy182's Avatar
Default Re: (b20integrapower)
just adjust the valves
EG_Civic_Si
Feb 6, 2011 04:05 AM
highwhey
Nov 11, 2010 05:53 AM
garyc17
Dec 24, 2008 08:02 PM
matix
Apr 18, 2004 09:32 AM
94GsRacer
Sep 19, 2002 02:43 PM
