h22a1 80 shot direct port???
Old Jan 22, 2006 | 08:54 PM
pavilionmike8's Avatar
Default h22a1 80 shot direct port???
ok i've search and didn't find the answer i need or so much agrument that i dont' understand. here is the deal for a month now i been thinking about nitrous (zex wet ) on my h22a1 i been researching and some say 75 is right for the h series and some say it is too much and other say 80 is fine. ok today i went to the performance shop and the mechanic told me that on my engine (h22a1) 80 shot direct port zex wet shot is safe on mine as long as i dont spray all the time.. is this too much for my engine? h22a1 has around 190 hp? so my question is should i get it or is it too much? MY ENGINE IS ALL STOCK...but if getting zex is safe then i will get fuel pump, intake, headers, lightweigh flywheel, clutch, but i need to know now is, is 80 shot direct port a good idea or bad? (im just planning on spray only when i go the raceway...)
Old Jan 22, 2006 | 08:58 PM
CGags13's Avatar
Default Re: h22a1 80 shot direct port??? (pavilionmike8)
this could be searched.....the diff between an 80 and 75 shot is negligable
i stay away from nitrous...esp on a bone stock engine...
Old Jan 22, 2006 | 09:12 PM
Default Re: h22a1 80 shot direct port??? (CGags13)
like i said i did searched but there is people that is saying stuff when they don't know which make it confusing so i need to know from someone who knows or someone that has done it...im going nitrous for search but i need to know the answer to my question, thanks in advance
Old Jan 22, 2006 | 09:41 PM
CGags13's Avatar
ok well i havent done nitrous and here are my reasons...
risk of detonation
do not have forged pistons/weak ring lands on stock pistons
this is my street car and even though i want it to be fast, i want it to last so i find other alternatves
Old Jan 22, 2006 | 10:37 PM
hu's Avatar
hu
That much nitrous with a stock setup is asking for trouble. You need better pistons and rings.
Old Jan 22, 2006 | 11:14 PM
Default Re: (hu)
you think i should just go 50 shot with a dry kit??
Old Jan 22, 2006 | 11:23 PM
Default Re: (pavilionmike8)
can i spray 50 shot with a wet kit direct port? or is it only 80 and up for a wet?
Old Jan 23, 2006 | 08:54 AM
Chuckles99SH's Avatar
I think what they are suggesting is not using nitrous at all. And I second that. The risk if proper ******* your engine is pretty high. The risk of you doing something stupid and killing others is probably even higher. The problem with your stock bone engine is that the pistons are weak and will bust causing you to rebuild.
Old Jan 23, 2006 | 08:56 AM
98vtec's Avatar
moderator emeritus
Default Re: (Chuckles99SH)
75 shot can easily be taken by a healthy h22. Be sure to get it tuned.
Modified by 98vtec at 1:56 PM 1/23/2006
Old Jan 23, 2006 | 09:22 AM
The Weather Man's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">75 shot can easily be taken by a healthy h22. Be sure to get it tuned.</TD></TR></TABLE>
Exactly. Stress the word Healthy.
As long as you don't abuse the **** out of it - i don't see a problem why you can't do it. Make sure you have something like an s300 or something to adjust the timing when the nitrous is activated. With that, you'll be good to go.
Old Jan 23, 2006 | 09:50 AM
Default Re: (TheKINGPin)
im only going to use it a the raceway. so i guess im not going to abuse it..how is it dangerous for others if im not going around spray(like i said im going to only used the nitrous on the strip) should i just go 50 shot just to be safe ? or is that still a bad idea?
Old Jan 23, 2006 | 10:02 AM
Like we said before - a 75 shot is okay. Its direct port so its not bad at all. If you just did a wet shot(non-direct port) you would have some problems in the future. 75 shot is perfectly fine for you. You can do 50 if you want. When you buy the kit, it'll have nozzles for whatever setting you want. Way down to 35 i believe. Go for it.
Old Jan 23, 2006 | 10:07 AM
hu's Avatar
hu
Old Jan 23, 2006 | 10:37 AM
thank you that is the answer i was looking for
Old Jan 23, 2006 | 10:56 AM
98vtec's Avatar
moderator emeritus
fixed
116298civic
Honda Civic (2001 - 2005)
12
Mar 2, 2009 06:38 PM
The7thG
Feb 4, 2007 08:05 PM
exquivical
Jun 30, 2002 01:12 AM
2K1_ITR
Jun 23, 2001 04:35 PM
