would a map sensor make my car bogg?????
Old Jan 22, 2006 | 08:51 PM
88crxdxfastwhip's Avatar
Default would a map sensor make my car bogg?????
what does the map sensor do? would this make my car bogg down ? because my ecu is throwing a 3 and five.but the 5 is from the exhaust cause its on headers only.please help
Old Jan 23, 2006 | 02:17 PM
Default Re: would a map sensor make my car bogg????? (88crxdxfastwhip)
bump anyone??????????
Old Jan 23, 2006 | 02:39 PM
technine's Avatar
I remember when I plugged my MAP sensor with the wrong vac hose it bogged very, very badly, barely made it home from the shop. I was thinking wtf? and then I looked at the diagram and sure enough I plugged it wrong. I put it back the right way and car didn't bog anymore.
Old Jan 23, 2006 | 02:40 PM
racerxadam's Avatar
the map sensor the is ecu's main source of information on how much fuel to give the engine, so yes it could make the car bog if there was a problem with it. check the vacumm line going to the map, if its still messed up try replacing it with a known good one.
Old Jan 23, 2006 | 04:28 PM
Default Re: would a map sensor make my car bogg????? (racerxadam)
how would i check that where is it located i see a couple of lines that are like disconnected back there. sorry im kinda new i know im a lil dumb lol
Old Jan 23, 2006 | 07:18 PM
racerxadam's Avatar
map sensor is bolted to the firewall on obd 0 cars, it should have a 3 wire plug going to it and a vacuum line
Old Jan 24, 2006 | 01:52 PM
what is odb 0? this is a d16a6 and my other one is a d15b.Which one is odb 0? and do you know where i can find a picture of this map sensor? i see a couple of things but i dont see three lines coming off of it.This is a 89 hf with d16a6 swap could it be missing???? please help
Benny Bao
Oct 14, 2014 11:47 AM
MatthewMenze
Engine Management and Tuning
May 1, 2014 01:24 PM
