Swaping my stock H22A manifold for Type S one?
Old Jan 22, 2006 | 07:51 PM
r1de4life's Avatar
Default Swaping my stock H22A manifold for Type S one?
Im thinking about replacing my stock H22A intake manifold with a Type S one what do you think is that a good idea or what?
Old Jan 22, 2006 | 07:57 PM
98vtec's Avatar
moderator emeritus
Default Re: Swaping my stock H22A manifold for Type S one? (r1de4life)
not worth the minimal ponies you will get out of it.
Old Jan 22, 2006 | 08:16 PM
r1de4life's Avatar
Default Re: Swaping my stock H22A manifold for Type S one? (98vtec)
really? so dont even bother doin it?
Old Jan 22, 2006 | 08:37 PM
98vtec's Avatar
moderator emeritus
i wouldnt...the only thing differnt between your current mani is that the secondary valve ports are a little larger.
Old Jan 22, 2006 | 09:51 PM
r1de4life's Avatar
does it give you any more Hp or torque and if so how much? What Manifold would you recomend to put on a H22?
Old Jan 22, 2006 | 10:50 PM
Don Jefe's Avatar
Well, this is entirely based off of what ive gathered about h22 intake manis, but to see the most benificial gains (we're not talking 5 peak whp at 10k rpm), most would suggest installing a euro-r manifold. If im not mistaken, it still retains the secondaries, which helps keep the torque down low.
Another option may be to port your current mani and port-match the throttle body as well. Although im not entirely sure of this route and it's gains. Good luck.
Old Jan 22, 2006 | 11:10 PM
vietdragontekx's Avatar
euro R manifold is the best one to go for the h22 for NA built. but u need to customize a kit to put on a h22a.
jdm 1080p
Mar 17, 2013 05:20 AM
ESP.net
Jan 14, 2008 01:24 AM
BlueDemonAccord
Apr 27, 2004 11:44 AM
92h22a
11
Oct 1, 2003 11:13 PM
se93
Aug 17, 2002 10:41 PM
