1990 honda crx wont start but cranks
i have a 1990 honda crx it will crank but will not start.. it has a good battery, main relay is good, i changed the pcv valve, it sparks, i think its gettin fuel i took the line off and it sprad (in a jug) it has only hot and cold injectors its throttle body please help is there a fuel line somewhere i can check?!?!?!
it has all thati got it retimes, it has spark, i donno about fuel i took the line off the presser regulaor and it sprays, so what else can it be? new battery, new pcv valve, what the compression need to be? the ecu needs to blink once? right becuase it does it blink like a sec later cuts off, it reads no codes. i just donno what else to check, my main relay clicks like normal, if something was messed up in the engine would it still crank, like if something isnt workin properly would it crank,?? would the crankshaft postion sensor make it not start? or a oxygen sensor? what about a vacume line cloged? please think and help me
rockcity
Jul 31, 2008 11:57 AM
Luserkid
42
Jun 17, 2004 04:39 PM
