car was laggin......then my car jus died out no where.....problem?
Old Jan 22, 2006 | 06:03 PM
akteamster's Avatar
Default car was laggin......then my car jus died out no where.....problem?
car:96 ek with a jdm b18c
i was driving my car today on the highway and all of a sudden it started to lag. what i mean by lag is that is didnt pull as hard as it usually does, and it seemed to sputter a bit...at idle it seemed to sputter also. i drove to my destination figured it was maybe bad fuel or a clogged fuel filter? that was causing it to lag and sputter.
3 hours later i went to drive it and was on the highway still same problem......and then it jus died on me outta no where. NO CEL's, sparkplugs are only 2 months old, used 93 octane from bp gas. I tried push starting it but car would not turn on at all. it cranks when i try to start it reguarly but doesnt actually start. i believe it started once but shut off right away. could is be that the motor is being starved of fuel?.......am not sure......i am going to take a look at it tom but before i do i want some expert advice from anyone as to what could be the cause.
ANY INPUT is appreciated
what could the cause of the problem be?
i am thinking mayb
1. clogged fuel filter?
2. could the stock DX fuel pump have gone bad?
3. clogged injectors?
Old Jan 22, 2006 | 06:42 PM
akteamster's Avatar
Default Re: car was laggin......then my car jus died out no where.....problem? (akteamster)
bump for some answers.......
Old Jan 22, 2006 | 06:44 PM
x_outlaw_x's Avatar
same **** hapened to me today too, im still looking for answers...my thread is here https://honda-tech.com/zerothread?id=1501668 that might help you get some answers
Old Jan 22, 2006 | 06:46 PM
GdmLaz's Avatar
you have a fuel gauge??? if you do check fuel pressure also check for spark
Old Jan 22, 2006 | 06:49 PM
Runnerdown's Avatar
I say distributor problems....
Old Jan 22, 2006 | 06:52 PM
akteamster's Avatar
Default Re: (Slammed92hbonN20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">you have a fuel gauge??? if you do check fuel pressure also check for spark </TD></TR></TABLE>
i will hook up a fuel pressure gauge i jus got tom.........thanks for the suggestion...........bad distributor? would changing the cap n rotor help mayb?
Old Jan 22, 2006 | 06:53 PM
Under_Pressure's Avatar
Default Re: car was laggin......then my car jus died out no where.....problem? (Runnerdown)
check fuel, spark. Try letting the car cool down for about 3 hours and trying again. If it starts it may be your main relay. Like i said if u have fuel pressure its not it.
Old Jan 22, 2006 | 07:12 PM
akteamster's Avatar
Default Re: car was laggin......then my car jus died out no where.....problem? (92h22alude)
willll do........any more inputttttt?
Old Jan 22, 2006 | 07:29 PM
akteamster's Avatar
bump for some more answerssssssss
killaj12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">I say distributor problems....</TD></TR></TABLE>
similar thing happened to me, turned out to be a bad distributor
Old Jan 22, 2006 | 07:58 PM
fizeks's Avatar
Default Re: car was laggin......then my car jus died out no where.....problem? (killaj12)
im going to say distrubutor... when mine went out .. it just lagged horrible then tried to give it some gas and then it just died no cel.. your problem sounds just like mine when it went out
Old Jan 22, 2006 | 08:07 PM
p10hlm's Avatar
Default Re: car was laggin......then my car jus died out no where.....problem? (fizeks)
sounds like your coil/ignitor is bad
Old Jan 22, 2006 | 08:11 PM
Krussty420's Avatar
check your fuel pump ground its located just beside your thermostat . Check all your grounds
Old Jan 22, 2006 | 09:00 PM
o5mar1's Avatar
i say its your distributor, buy a new one.
moacsupreme
Oct 19, 2014 02:15 PM
MariaTheMonkey
Aug 31, 2006 11:37 PM
frontrangefreedom
Mar 16, 2005 07:46 PM
