CNC mill need something to build
Old Jan 22, 2006 | 05:24 PM
Super Chicken's Avatar
Default CNC mill need something to build
Hey all, I just bought one of these for a project at work, we're not building anything with just using it as an engraver for now, any suggestions where to find cam drawings to build **** with this?
Home page more info http://www.microkinetics.com/cncdmill.htm
Old Jan 22, 2006 | 05:35 PM
silentdaredevil2's Avatar
Default Re: CNC mill need something to build (Super Chicken)
man that thing is expensive 8k but you could make anything really if u know about G and M codes and programming stuff like battery tie downs, turbo flanges, wire cover etc..
Old Jan 22, 2006 | 07:38 PM
92hondalude's Avatar
Default Re: CNC mill need something to build (silentdaredevil2)
damn! nice toy
Old Jan 22, 2006 | 08:38 PM
.RTErnie's Avatar
Default Re: CNC mill need something to build (92hondalude)
i want one! all diff kinds of flanges....
Old Jan 23, 2006 | 03:47 AM
Timmah!!'s Avatar
Default Re: CNC mill need something to build (~RTErnie~)
I need 2 brake brackets made
Old Jan 23, 2006 | 04:47 AM
weiRtech's Avatar
OG Fabricator
i'm not sure if i'd push that machine too hard. i'd hesitate to cut steel on it but aluminum should be ok. a good little starter project would be to make some t3 oil outlet flanges. they are pretty basic, although i'm not so sure you'd have the travel for a 1/2"NPT tap drill unless you cut it down shorter. have fun!
Old Jan 23, 2006 | 07:27 AM
snoochtodanooch's Avatar
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">i'm not sure if i'd push that machine too hard. i'd hesitate to cut steel on it but aluminum should be ok. a good little starter project would be to make some t3 oil outlet flanges. they are pretty basic, although i'm not so sure you'd have the travel for a 1/2"NPT tap drill unless you cut it down shorter. have fun!</TD></TR></TABLE>
yea that thing does look pretty small
Old Jan 23, 2006 | 09:40 AM
jon volk's Avatar
Default Re: (snoochtodanooch)
Damn, for 8g's ya could have found a decent full size bridgeport style cnc controlled mill.
Old Jan 23, 2006 | 06:08 PM
for 8k that thing will cut steel no problem i had a grizzly mini mill i paid 500 bucks for and it cut steel just fine
Old Jan 23, 2006 | 07:10 PM
Default Re: (silentdaredevil2)
Material won't matter to this unit. The reason we bought is to do sequentially numbered parts (ww0001, ww0002...etc) and the full size bridgeports require alot to change the engraving program whereas this unit is super easy to change the program from one bit of text to the next. I will be buying tooling for it to work aluminum first and then i'll move on to steel when I build up my skillz.
Old Jan 24, 2006 | 04:16 PM
make sure u get aluminum cutting endmills
Old Jan 24, 2006 | 05:02 PM
Yea don't use cutters designed for steel on aluminum you'll wind up with a tool coated in aluminum
Old Jan 24, 2006 | 05:56 PM
Default Re: (Super Chicken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken &raquo;</TD></TR><TR><TD CLASS="quote">Yea don't use cutters designed for steel on aluminum you'll wind up with a tool coated in aluminum</TD></TR></TABLE>
not even that they just don't have enough clearing room for aluminum
Welding / Fabrication
Mar 30, 2012 08:45 AM
Gauged92
Jul 18, 2009 09:04 PM
b16b18
Oct 14, 2008 08:41 AM
Hatch1990SI
Mar 15, 2005 08:48 PM
