Help! DA Fan troubles.....?
Old Jan 22, 2006 | 05:24 PM
crxsir07's Avatar
Default Help! DA Fan troubles.....?
My girls got a 90 RS, and it runs good (not hot or anything...) and after it's turned off the Engine fan will run forever, like a couple of hours at least,...WTF? I was thinking Thermostat mabey, hopefully not an electric problems, any help would be appreciated Thanks!
Old Jan 23, 2006 | 03:09 AM
scheistermeister's Avatar
fan relay, mine does it to, i just havent gotten around to getting another relay. heres a pic of where it is
Old Jan 23, 2006 | 07:31 AM
M Coop's Avatar
Default Re: Help! DA Fan troubles.....? (crxsir07)
If you want to narrow it down and make sure it's the relay, you can take another matching relay and swap it with the fan relay, if you still have the same problem it's most likely something else, but it sounds like the relay is the problem
Old Jan 23, 2006 | 12:13 PM
..::91TEG-G2::..'s Avatar
Default Re: Help! DA Fan troubles.....? (M Coop)
the fan on my DA rarely turns on unless its crazy hot.. im not sure if this is normal or if my car is just running really cool like the radiator is doing its job...
mine never turns on in the winter and sometimes turns on in the summer when its like 95+ outside.. thats not to mention the engine bay temp
Old Jan 23, 2006 | 03:36 PM
crxsir07's Avatar
Default Re: Help! DA Fan troubles.....? (..::91TEG-G2::..)
Thanks alot guys! i'm going to look at it tommorow, i'll let you know how it goes
Old Jan 23, 2006 | 04:00 PM
wytechoppin's Avatar
Default hey (crxsir07)
ok like they said fan relay.. or the fan switch.... or more then likely you thermostat... it really cant be anything else.. unless is your radi. fuse
19 crx 89
10
Aug 26, 2010 12:38 PM
jshireaz
Aug 9, 2007 04:47 AM
crxkid24
Sep 22, 2006 12:42 PM
