rsx owners ... ? about sway endlinks
just curious for you rsx owners on here, if your having problems with your stock sway bar endlinks breaking a lot, espically when you upgrade to the bigger front or rear bars. i know its a common problem on the 01 - up civics.
How hard do you corner your car? I've run Hotchkis' 27mm rear hollow sway bar with their upgraded metal endlinks and they've bent quite easily due to shitty installation on my part. I wouldn't be surprised if the stock endlinks snapped in an autocross.
i do take some hard turns every now and then, i do plan on starting to go to autocross events within the year when my suspension is done. i plan on bolting up my DC5 rear sway and the progress front sway on my em2 sometime soon so should i spend the extra money for some better endlinks and do it all right the first time ?
Modified by mrDFWmechanic at 7:03 PM 1/22/2006
Shaynepolevault
Jan 7, 2010 11:06 PM
StuDizzle
Aug 24, 2006 05:27 PM
crazydjr26
Oct 13, 2004 12:22 PM
