quick main relay question
Old Jan 22, 2006 | 05:16 PM
CoolRedXylophone's Avatar
Default quick main relay question
will they check one of these at autozone, advance ect. for free?
thanks
Old Jan 22, 2006 | 05:23 PM
kulangot's Avatar
Default Re: quick main relay question (CoolRedXylophone)
i don't think so...but why don't you call them and ask..
Old Jan 22, 2006 | 05:25 PM
Default Re: quick main relay question (kulangot)
hmmm, good idea, how much are these to replace
michael_s's Avatar
u can check it
all u have to do is turn the key and it should make a click noise u know its workin i fixed like mine 3 times becuase they fail alot. plus i was gettin it at a junk yard i found one i have goodluck with now
Old Jan 22, 2006 | 05:28 PM
Default Re: quick main relay question (michael_s)
no fuel is reaching the engine and ive read through the forums that the main relay being out makes the fuel pump faulty or whatev
can you buy a new one tho?
Old Jan 22, 2006 | 06:45 PM
SiRay13's Avatar
yeah, the main relay is probably a part that you have to get from the dealer, when i bought mine i think it was about 80 bucks new. You should be able to hear both the fuel pump and the main relay turn on when you turn on the accessories, just listen closely for the fuel pump- kind of hard to hear, but the relay will click, you can even feel it if you put your hand on it, right above the hood relase.
3easy21
Jun 11, 2012 07:27 PM
jerome^galon
Jan 4, 2012 07:03 PM
Ludespeed13
Dec 26, 2005 12:20 PM
89 exi nut
Oct 4, 2004 01:45 PM
RenoRacing
Sep 8, 2002 09:41 PM
