'01 Prelude Mystery Leak
Old Jan 22, 2006 | 05:02 PM
jmyers's Avatar
Default '01 Prelude Mystery Leak
My '01 Prelude (79K miles) is leaking what appears to be hydraulic fluid under the driver's side front fender. There has been quite a bit of fluid on my garage floor; however, it doesn't appear that brake fluid or power steering fluid levels are down in their reservoirs. Any idea what might be causing this?
Old Jan 22, 2006 | 05:09 PM
The Weather Man's Avatar
Is it on the driver's or passengers?
What color is the fluid?
Old Jan 22, 2006 | 05:12 PM
jmyers's Avatar
Default Re: (TheKINGPin)
Clear, and on driver's side.
Old Jan 22, 2006 | 05:17 PM
Could be brake fluid - coming from the brake lines or could be clutch fluid(which is brake fluid).
Aka hydraulic fluid. Check your master and slave cylinder lines.
Old Jan 22, 2006 | 05:22 PM
jmyers's Avatar
Well, the brake fluid levels in the reservoir don't seem to be down. Is there a clutch fluid reservior that I can check?
Old Jan 22, 2006 | 05:23 PM
Yes. Should be right next to the brake fluid resevoir. Right right next to it.
Actually, it might be different for 5th gens.
Does your clutch pedal seem weak at all?
Old Jan 22, 2006 | 06:52 PM
BB6racer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKINGPin &raquo;</TD></TR><TR><TD CLASS="quote">Actually, it might be different for 5th gens.</TD></TR></TABLE>
5th gens have the clutch fluid right next to the brake fluid as well. but if it was brake fluid, it would have a brown color to it. are you sure its not from the AC? can you tell us what is directly above the leak on the floor?
Old Jan 22, 2006 | 11:34 PM
DLudist's Avatar
what about the shock's fluid? like a blown shock or something
Old Jan 23, 2006 | 06:26 AM
jmyers's Avatar
Default Re: (DLudist)
The color of the hydraulic fluid is, I would say, a very light yellow-brown--sorta like sewing machine oil.
Anway, I took the car to the shop today, so we'll see what they say.
Thanks, all, and I'll let you know.
Old Jan 23, 2006 | 07:03 AM
jmyers's Avatar
Default Re: (jmyers)
I guess I just qualified for the dumbass of the year award.
The shop just called me and said the leak was from a quart of Mobil 1 oil that had fallen down and out of sight. Who knows how long it had been there, or why it started leaking!
Duh.
Old Jan 23, 2006 | 08:59 AM
Skidtron89's Avatar
Ya your a dumbass for sure. Sorry I had to comment that is funny and even my girlfriend is laughing at you.
Old Jan 23, 2006 | 09:10 AM
.......... :sighs: **** happens
Be lucky it wasn't anything serious though. I'd take the fallen quart of oil any day over a leak.
globy123
Sep 27, 2009 05:32 PM
stackz
Nov 26, 2007 11:32 AM
ieatrice
Jun 23, 2005 12:27 AM
2k1 SSM GSR
Mar 23, 2005 10:02 AM
Cosworth
24
May 22, 2002 07:49 AM
