4x100 on a 5th gen?
ok i kow that the accord's lug pattern is 4x114.3 but how do ITR rims fit on accords? i thought the ITRs lug pattern was 4x100.. if the ITRs will fit on an accord will any 4 lug pattern wheels fit? if they fit wut is the difference besides the obvious numbers? will a 100 pattern fit loosly or will there be any danger with the rim being bolted on?
Check out P Adams post in this link. It has the bolt patterns for just about every Honda.
https://honda-tech.com/zero...90233
JDM ITR 15" 4x114 Wheels/Tires
Home > JDM Wheels > 15" Wheels > JDM ITR 15" 4x114 Wheels/Tires
Product condition : Used
ITR 4x114.3 JDM rim available from
PasswordJDM.com
http://www.passwordjdm.com/pro...ion=9& P_ID=526&strPageHistory=&strKeywords=&
JDM DC2 Integra Type R 15" 4x114.3 wheels.
*out of stock, please call for ETA.
PLEASE NOTE THIS WILL NOT FIT NORMAL CIVIC/INTEGRA BECAUSE IT USES NORMAL 4x100 BOLT PATTERN.
(THIS IS AN OVERSIZED PRODUCT. LISTED PRICES DO NOT INCLUDE SHIPPING COSTS. YOU WILL RECEIVE A SHIPPING QUOTE THE FOLLOWING BUSINESS DAY. PLEASE SEE THE SHIPPING CHART BELOW FOR MORE DETAILS)
Is this what you're speaking of?
P
PasswordJDM.com
P
not really speakin of any wheel in spacifics, just wonderin, will a 4x100 pattern wheel fit on a 5th gen accord? and will ITR rimes fit on an accord? if so wut year rims frm wut vehicle. the PWRd JDM DC5 wheesl are 4x114 pattern not 114.3 or did they just leave the .3 out?
The 4x100mm bolt pattern WILL NOT FIT on a USDM Accord after the end of the 1989 model year. From that point on (1990 and later) it has been either 4x114.3mm or 5x114.3mm bolt patterns.
To try to fit a 4x110mm on a 4x114.3 hub would involve very careful (accurate) machining, not only to relocate the lug holes, but the center piloting hole has to be enlarged from 56.1mm to 64.1mm as well. If this is not done perfectly, the wheel will not run true
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmwestcoaststyle »</TD></TR><TR><TD CLASS="quote">not really speakin of any wheel in spacifics, just wonderin, will a 4x100 pattern wheel fit on a 5th gen accord? and will ITR rimes fit on an accord? if so wut year rims frm wut vehicle. the PWRd JDM DC5 wheesl are 4x114 pattern not 114.3 or did they just leave the .3 out?</TD></TR></TABLE>
once again, you NEED 4x114.3mm (4x4.5") wheels...1996 ITR's in japan ONLY came with a 4x114.3 lug pattern...however you need a 10mm (i think thats the right size) up front to clear the accord's caliper.
that is the ONLY year ITR wheels that will fit on a 90's I4 accord
