FS: Everything.. Swaps /heads/block/tranny/all my k stuff
OK guys, everything is getting parted out. if you want something let me know.. thanks. All parts are in perfect working order unless noted.
Chad
541 337 8073
ITR K20a Complete head 10k KM 1300
ITR K20a Valve Cover Brand new **sold**
ITR K20a Intake Manifold 10k KM 250
ITR K20a Throttle Body with 70mm Bore all sensors working 275
ITR K20a Injectors 10k KM 125
ITR K20a Fuel Rail 30
ITR K20a Vtec Solnoid 100
TSX K24a2 Complete Block New 1500
TSX K24a2 Knock Sensor New 50
TSX K24a2 Head Gasket New 75
RSX-S K20a2 Oil Pan 17k Miles 150
RSX-S K20a2 Oil Pump and Pickup **sold**
RSX-S K20a2 Engine and Charge Harness 17k Miles 200
RSX-S K20a2 Knock Sensor New 75
RSX-S K20a2 Intermidiate Shaft and Both Axles 17k Miles
RSX-S K20a2 Alternater 17k Miles 100
RSX-S K20a2 Starter 100
RSX-S K20a2 Tranny 17k Miles No Grinds 1000
RSX-S K20a2 Shifter Cables 17k Miles 100
RSX-S K20a2 Revo Short Shifter **sold**
Buddy Club Oil Filler Cap **sold**
Buddy Club Radiator Cap **sold**
A.R.P Head Studs New 85
RSX-S K20a2 Exedy Stage 2 Thick Cerematlic Clutch & Flywheel New 650
RSX-S K20a2 DC Stainless Steel Race Header *sold*
RSX-S K20a2 Buddy Club Spec III Exhaust **sold**
Sun Automotive Hypergound System 3k Miles 65
Hondata K-Pro Virgin ECU 3k Miles **sold**
Hondata Intake Manifold Gasket 3k Miles 45
C&R Radiator w/ Spal Fans 3k Miles 450
Mugen Thermostat and Switch 3k Miles **sold**
Hasport K series EG/DC2 Motor Mount Kit NEW 575
RSX-S K20a2 Vtec Solnoid 17k Miles 100
CRV K24a1 Head Valvs/Springs/retainers 200
Buddy Club Shift **** **sold**
45 Degree VTC Cam Gear Brand New **sold**
RSX-S K20a2 Intake and Exhaust Cam Gears 17k Miles 100
*3* RSX-S K20a2 Fuel Railes 25/piece
*3* RSX-S K20a2 Map Sensors 25/piece
*2* RSX-S K20a2 Crank Angle Sensors 25/piece
*2* RSX-S K20a2 Timing Chain Covers 90/piece
*2 sets* RSX-S K20a2 Cam Angle Sensors 50/per set
*1* RSX-S K20a2 Crank Pulley w/ bolt **sold**
*3* RSX-S K20a2 Idler Pullies / Belt tensioner 40/piece
*1 set* RSX-S K20a2 New Valves 75
*2* RSX-S K20a2 Timing Chains with tensioner and guides 50
*2* RSX-S K20a2 oil pump chains 25
RSX-S K20a2 Idle air Control Valve 40
RSX-S K20a2 Clutch and Pressure Plate 17k Miles 100
RSX-S K20a2 Fuel Pump Housing Mod'd for ITBS (TWM) 50
RSX-S K20a2 Fuel Pump 17k Miles 50
RSX-S K20a2 VTC Oil Sensor 50
RSX-S K20a2 Rods 17k Miles 125
RSX-S K20a2 Spark Plug Cover **sold**
TSX k24a2 Shorty Header New **sold**
TSX k24a2 Intake Manifold **sold**
TSX k24a2 TB with cracked sensor housing but still working **sold**
TSX k24a2 Head Bolts used but within spec to re use 40
RSX-S K20a2 Head Bolts used but within spec to re use 40
RSX-S K20a2 Evap Lines New 45
RSX-S K20a2 Cooling Pipe New 50
RSX-S K20a2 Thermostat and houring New 50
RSX-S K20a2 OEM Wheel Lock Kit 40
RSX-S K20a2 Climate Controls
2004 PWP titanium Interior. Selling full interir Minus front seats/and belts/pass airbag/Headliner/A pillars everything else will sell..
Modified by chad_everson at 11:50 PM 2/5/2006
Chad
541 337 8073
chad_everson
Northern California (Sales)
Jan 24, 2006 04:13 PM
