Honda crx
I have a honda crx 1990 and one monring it was somewhat cold.. i started it and gave it some gas then i reved it to about 5000rpms and i let the gas go it died and make a weird noise... i dont know what wrong i have a air hose and blew air into the intake it tried to start so i canged the pcv valve nothing.. i put startin fluid into it nothing.. its gettin spark, got a good battery, and it has compression.. help please thanks email me at sponge_bob152003@yahoo.com or write it on here
you had ten minutes to get to school, so you cold revved it to 5 grand? are you 16? you should let it idle for at least 15 seconds before ever touching the gas if it hasnt been run in several hours. take your fuel rail/injectors off the intake manifold, turn the engine over and see if fuel squirts out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michael_s »</TD></TR><TR><TD CLASS="quote">
...get a try but i have to blow air into the intake
What the heck do you mean by this?
on the intake mainfold, fuel rail is on top of all the feul injectors.
honelsty if you don't know what a fuel rail is then i think you should take your car to a mechanic who knows what he is doing.
I let my car idle, when i cold start it, for at least 3 minutes before touching the gas. When i start up and the engine is still warm i still let it idle for 45 seconds before touching the gas.
you hae to see if the fuel is getting into your combustion chamber....so you will have to pull off your fuel rail and injectors...then cranck your engine over....see if fuel is coming out of the injectors.
i recommened having 2 ppl helping....and point the injetors in something like a milk jug. see if both are shooting fuel or not? from there you can find out if you have fuel, did you check your compression on all cylinders?....just asking
If anyone else has a better way, please speak up as i don't know if my way is the best way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey »</TD></TR><TR><TD CLASS="quote">using 2 usernames is
Against the TOS too. That can get you thrown off h-t.
</TD></TR></TABLE>Against the TOS too. That can get you thrown off h-t.
alscrx
Jun 18, 2007 12:53 PM
