91 crx hf disc conversion
Old Jan 22, 2006 | 02:04 PM
91ef8sir's Avatar
Default 91 crx hf disc conversion
I changed my 91 crx hf brakes to 91 integra spec
91 integra front brakes
91 integra rear brakes with trailing arm and e-brake cable
But now my brake pedal feels soft and it goes down when I start the car it still stops pretty good but it doesn't feel safe.
I have heard that I need the proportioning valve from the 90 - 91 crx si and master cylinder to work correctly.
If im wrong please give some advice thanks
Old Jan 22, 2006 | 02:19 PM
CRX Toad's Avatar
Default Re: 91 crx hf disc conversion (91ef8sir)
You need to bleed the crap out of the brakes. And the prop valve isn't going to make that much of a difference.
Old Jan 22, 2006 | 03:17 PM
Mr.Chow's Avatar
Default Re: 91 crx hf disc conversion (CRX Toad)
I was thinking about doing that on my hf as well. How hard was the conversion? and where did you get the parts? junkyard?
Old Jan 22, 2006 | 03:20 PM
DocSean's Avatar
Bleed, bleed, and rebleed to double check. A larger master cylinder will give you a stiffer brake pedal feel which may have occured due to the swap, but nodoby ever seems to know for sure.
Old Jan 22, 2006 | 05:23 PM
91ef8sir's Avatar
Default Re: (spankjelly)
I got it done at a shop called Honda Fiend in Covina he got the parts from ylm motors
Old Jan 22, 2006 | 05:26 PM
aznboi_2's Avatar
Same problem i had on a toy camry and escort. You just have to bleed it and it should work fine. You should also have someone help you do it. It will be easier.
Old Jan 22, 2006 | 05:28 PM
aznboi_2's Avatar
I jsut posted a thread too. I need help with my swap if you can help me out. I found 97gsr in the junk yard. What stuff would i need off from that car to swap into my crx hf? I want both front and rear.
crxmadness
Suspension & Brakes
Feb 20, 2006 04:25 PM
quintanaporvida
Aug 13, 2005 05:06 PM
plasmaloaf
Nov 1, 2003 06:12 AM
fajoza45
Dec 13, 2002 11:56 PM
