itr valve springs / retainers..
Old Jan 22, 2006 | 01:15 PM
integra95gsr's Avatar
Default itr valve springs / retainers..
if i plan on doing an itr or ctr cam swap in my 95 gsr, ive been told to get the itr valve springs and retainers..
how much are the springs/retainers worth... used? new?
how do i tell the difference from other springs/retainers so i dont get ripped off?
is there a how-to site on where i can find how to install them correctly and all the torque specs?
Old Jan 22, 2006 | 03:47 PM
anyone?
Old Jan 22, 2006 | 03:55 PM
Dartanian's Avatar
Default Re: itr valve springs / retainers.. (integra95gsr)
ITR and GSR retainers are identical. You should only be looking for the intake side since you can switch your GSR intake springs to the exhaust side.
Old Jan 22, 2006 | 03:58 PM
is this true?
also would i need to change to ITR Valves?
Old Jan 22, 2006 | 05:04 PM
ttt!
Old Jan 22, 2006 | 08:46 PM
jdm'dc2sc61's Avatar
Default Re: (integra95gsr)
pm sent.
Old Apr 6, 2006 | 07:38 PM
Default Re: itr valve springs / retainers.. (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">ITR and GSR retainers are identical. You should only be looking for the intake side since you can switch your GSR intake springs to the exhaust side.</TD></TR></TABLE>
is that true? anyone?
also if thats not my other "?" is, would it be fine if i bought just the itr outer springs i&e side. and used my gsr inner springs? http://www.inlinefour.com only sells itr outer springs.. but i found a user on here selling both outer and inner.. would it be necessary?
Old Apr 6, 2006 | 09:22 PM
import810's Avatar
yes that is true but buy from len!!!! I got my itr inner + outer ITR intake valvesprings for $81 shipped. He is an awesome guy and is very helpful. His username is len
Old Apr 7, 2006 | 10:15 AM
^^ thanks alot man!
Old Apr 7, 2006 | 11:34 PM
TOP! for more info
Old Apr 8, 2006 | 02:27 PM
import810's Avatar
The ITR intake springs are yellow on top. That side faces the valve cover.
You don't torque the valvesprings down you simply compress them. Buy the snap-on tool or rent one to compress the retainer and spring to put the keepers in. IMO it is easier to do all of this with the head off.
If I were you I would just buy them new because they are cheap and you know that they are good.
Old Apr 8, 2006 | 03:07 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: (import810)
i have a set of type R intake springs complete set low mileeage $45 lmk
B HATCH
13
Sep 6, 2004 12:25 PM
kelly
Mar 4, 2004 08:15 PM
riceball777
Oct 22, 2003 03:49 PM
pistol
Apr 17, 2002 09:49 PM
2fknlo
Feb 20, 2002 10:13 PM
