90 DX to ZC Wiring
i heard you can use the Si harness...is this tue or not cause i've also heard that you cant....Hasport does the harness for 200 bucks. Do you think its worth it? I am tryin to do it right though.....so does the Si harness work for what i am tryin to do? thanks
Dude, go to http://www.hasport.com and look under the swaptech section. There it will tell you what wires need to go where. Cross reference that with a few of the other ZC swap pages found on the net and save yourself some dough. The wiring is not hard, it just takes some patience and the right frame of mind. I did one once, when i was finished, I was like"is that it?". The car started right up. Don't bother with the si harness, because I think that you would have to get the entire harness out of the car. You would have to ge the entire engine compartment harness, and the under dash harness, and the resistor box and everything. Don't bother. Just do enough research, print out everyones version of the wiring instructions, you will get it.
Go to http://hybrid.honda-perf.org/
they have some instructions on how to do it yourself also.
88crxdxfastwhip
Nov 3, 2005 06:46 AM
komat
Oct 16, 2004 03:03 PM
