pictures of a b20 in a DA
Old Jan 22, 2006 | 11:36 AM
Louis53123's Avatar
Default pictures of a b20 in a DA
ive been searching for pics of a b20 in a DA....i just bought a JDM b20....i want to see how it fits,,,im werryed about the intake manifold clearance...and of course the engine is outta an automatic CRV....so i wanna see how my b18 tranny is mounted...(not good with tranny werk yet),,,,, the only reason i got a b20 is cause of the torque and compression...better to build vtec on then ls...anyways pics would be much appreciated THANX!
Old Jan 22, 2006 | 11:55 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: pictures of a b20 in a DA (Louis53123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louis53123 &raquo;</TD></TR><TR><TD CLASS="quote">ive been searching for pics of a b20 in a DA....i just bought a JDM b20....i want to see how it fits,,,im werryed about the intake manifold clearance...and of course the engine is outta an automatic CRV....so i wanna see how my b18 tranny is mounted...(not good with tranny werk yet),,,,, the only reason i got a b20 is cause of the torque and compression...better to build vtec on then ls...anyways pics would be much appreciated THANX!</TD></TR></TABLE>
well youre right about one thing; it has better torque. BUT, im pretty sure the LS has higher compression than the b20.
Old Jan 22, 2006 | 12:06 PM
AnDThEnWuT's Avatar
why do you need pictures, it looks exactly like your stock ls motor. And about the intake mani clearance, you'll be using your old one, so there wont be any problems.
Old Jan 22, 2006 | 12:15 PM
projectTeG's Avatar
Default Re: pictures of a b20 in a DA (AnDThEnWuT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnDThEnWuT &raquo;</TD></TR><TR><TD CLASS="quote">why do you need pictures, it looks exactly like your stock ls motor. And about the intake mani clearance, you'll be using your old one, so there wont be any problems.</TD></TR></TABLE>
yup the only thing that will be different is the valve cover you get the 96+ ls valve cover.
Old Jan 22, 2006 | 12:35 PM
you might be able to raise the compression, to, i dont know, about 15:1 if you use dry gas. jp.
Old Jan 22, 2006 | 12:51 PM
mattcivic's Avatar
what i was gunna say
Old Jan 22, 2006 | 07:18 PM
tbsol's Avatar
yep. just looks like a b18a1 with a 98+ non-vtec valve cover.
Old Jan 22, 2006 | 09:33 PM
integra da's Avatar
nice pics that i cant see
Old Jan 22, 2006 | 10:16 PM
Louis53123's Avatar
ok....i wasnt sure if my b18 manifold fit....good lookin guys, thanx for the pic
Old Jan 22, 2006 | 10:21 PM
bks84's Avatar
Loved
yes any and all bolt ons for the ls will fit the b20b or b20z.
the b20b has 8.8:1
the b20z has 9.6:1
to determine if your engine is higher compression look for a knock sensor on the back of the block.
and here you go.
Old Jan 22, 2006 | 10:25 PM
Ruben19's Avatar
if i get a b20 i would raise the compression to 12:5.1.
B20b stock compression is 8:8.1
not very much
B20z is 9:2.1 still not very much.
Is good for turbo but im a all motor fan.
Old Jan 22, 2006 | 11:21 PM
watsvtecEK's Avatar
Default Re: (Ruben19)
woah, those b20's look exactly the same as my b18.
Old Jan 23, 2006 | 02:01 AM
XYU's Avatar
XYU
Ask me about vaginal warts
Here is a DC4 ..... pretty similar
Old Jan 23, 2006 | 10:06 AM
Louis53123's Avatar
thanx guys
Old Jan 23, 2006 | 06:34 PM
bks84's Avatar
Loved
Default Re: (D 2da A9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">woah, those b20's look exactly the same as my b18. </TD></TR></TABLE>
yep. nice observation.
the only difference - bore size, intake manifold, exhuast manifold and valve cover. oh, if you are lucky and get a P8R head, you have 33mm intake valves, bigger itnake ports, better cams and 84mm combustion chambers.
Old Jan 23, 2006 | 08:38 PM
Toadfart's Avatar
Default Re: (4sd4dr)
I can show you what a B20 with 11.5:1 compression looks like. But mine has a vtec head.
hellsyea2020
Jun 11, 2005 11:45 PM
xd69
Sep 10, 2004 03:48 PM
J T*
Jul 6, 2002 06:06 PM
