1998 LX tranny removal help
Old Jan 22, 2006 | 11:00 AM
1990hondaHF's Avatar
Default 1998 LX tranny removal help
I've got almost all the bolts holding the tranny to the engine.....the rear motor mount is out.....the pass side mount is out as well....all the electrical items have been removes...starter is out.....slave cylinder is out..axles are out.......is this all I need to remove? Will is just slide out just like the Civic models do? Thanks for your help.
Added: It looks like I might need to drop the whole subframe...I'm ready to go I just need a little "been there done that" help.
Old Jan 22, 2006 | 12:24 PM
hondadude's Avatar
Default Re: 1998 LX tranny removal help (1990hondaHF)
Yes you need a cross support for the engine to hang from, then drop the subframe
Old Jan 22, 2006 | 01:14 PM
YeuEmMaiMai's Avatar
Default Re: 1998 LX tranny removal help (hondadude)
he will also need to have a hydraulic jack to support the trans as it is being lowered otherwise he will get hurt. It would not be a bad idea to have a friend help as the trans will want to tip over.....
925EKCOUPE
Jun 28, 2009 04:40 PM
