04 civic si revving problems
Old Jan 22, 2006 | 08:21 AM
98slowvicEX's Avatar
Default 04 civic si revving problems
Hey all. Last night on the way home from the club i was having a little fun with the car. Chirping gears and what not. When i went to redline it in first it acted like the rev limiter somehow moved to 5k rpms. Now it will rev the exact same at 5k rpms as it used to at the redline. Up to 5k, and down to 4900k fast. The car is under warrenty, but its got me a little worried. Anyone have any ideas? thanks in advance.
Also, a little off subject, but can an rsx 6 speed tranny be dropped in the ep3 civic si with the k20a?
Old Jan 22, 2006 | 08:30 AM
Rusty_SI's Avatar
Default Re: 04 civic si revving problems (98slowvicEX)
It's normal. If you are at a standstill, the ecu limits revs to 5500. I mean, you dont really need more than that from a stop. If you are rolling, you can get to the real readline no problem.
Old Jan 22, 2006 | 11:08 AM
BarracksSi's Avatar
Yes, the RSX tranny can be put on the K20A.
Now... you're saying that it won't rev any higher than about 5K? Even on the move?
I would guess that it's in limp mode for whatever reason.
Old Jan 22, 2006 | 11:10 AM
redronin22's Avatar
Could be oil level is low. Was the car properly warmed up?
Old Jan 23, 2006 | 02:19 PM
Rusty_SI's Avatar
Default Re: 04 civic si revving problems (redronin22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redronin22 &raquo;</TD></TR><TR><TD CLASS="quote">Could be oil level is low. Was the car properly warmed up? </TD></TR></TABLE>
if you are rolling and you cant get to redline, there is a problem, but at a standstill the fuel cutoff is 5500rpm.
Old Jan 24, 2006 | 04:33 PM
01-1293's Avatar
Default Re: 04 civic si revving problems (Rusty_SI)
your car is fuct....take it in if it's under warranty
Old Jan 28, 2006 | 07:12 AM
Rusty_SI's Avatar
Default Re: 04 civic si revving problems (01-1293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1293 &raquo;</TD></TR><TR><TD CLASS="quote">your car is fuct....take it in if it's under warranty</TD></TR></TABLE>
Im not speculating damnit, my car does the same thing. If you arent moving you cant rev to redline. There are other threads about this topic.
Old Jan 28, 2006 | 10:13 AM
badassmthr4000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rusty_SI &raquo;</TD></TR><TR><TD CLASS="quote">
Im not speculating damnit, my car does the same thing. If you arent moving you cant rev to redline. There are other threads about this topic.</TD></TR></TABLE>
He is moving.....good contribution
Old Jan 28, 2006 | 09:40 PM
BarracksSi's Avatar
In case anyone didn't read his post...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98slowvicEX &raquo;</TD></TR><TR><TD CLASS="quote"> When i went to redline it in first it acted like the rev limiter somehow moved to 5k rpms.</TD></TR></TABLE>
This says to me that he tried to redline it while in gear. You can't be in gear and remain standing still. Now...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98slowvicEX &raquo;</TD></TR><TR><TD CLASS="quote">Now it will rev the exact same at 5k rpms as it used to at the redline. Up to 5k, and down to 4900k fast.</TD></TR></TABLE>
This sounds like he's bouncing off the rev limiter, except that instead of redline, it's now at 5K rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The car is under warrenty, but its got me a little worried. Anyone have any ideas? thanks in advance.</TD></TR></TABLE>
Have you taken it in yet?
Don't be surprised if they read the stored data on the ECU and discover that you've been beating the **** out of your engine. If they DON'T figure this out, and they don't accuse you of racing, then quietly accept whatever warranty work they'll give to your car.
Then, after it gets fixed, don't beat the living expletive out of your engine all the time. Yeah, Honda motors are rev-happy, but they still have their limits, and bouncing off the rev limiter isn't good for ANY engine.
Never mind that chirping the tires beats up your clutch & tranny...
[/scolding rant]
Old Jan 29, 2006 | 12:11 AM
sillyboybmxer's Avatar
If the car is not warmed up the ecu will not allow it to enter v-tec.
Old Jan 29, 2006 | 07:44 AM
EP3tune2RULE's Avatar
Default Re: 04 civic si revving problems (sillyboybmxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sillyboybmxer &raquo;</TD></TR><TR><TD CLASS="quote">If the car is not warmed up the ecu will not allow it to enter v-tec.</TD></TR></TABLE>
what v-tec??......
davidfillups
24
Sep 8, 2008 09:55 PM
WILD_WILL
Honda Civic (2006 - 2015)
Aug 16, 2006 04:20 AM
dglong
16
Jul 27, 2002 06:50 PM
FredoSP
Jun 24, 2002 05:01 PM
Dokta
Apr 24, 2002 07:34 AM
