zc swap oil problem
Old Jan 22, 2006 | 08:08 AM
del-sol-95's Avatar
Default zc swap oil problem
hey guys me and my buddies just finished swapping a zc swap in his crx and after we put the engine in i saw an oil leak on the intake side under the valve cover. it looked like it was leaking out of a hole with threads on it. i was wondering if a zc has an external oil line.
Old Jan 22, 2006 | 08:18 AM
Honda Crx's Avatar
Default Re: zc swap oil problem (del-sol-95)
is the oil filter on? hole with threads spray some carb and choke cleaner on there spray it off with air compressor and wait for it to leak then you will find out where it is leaking from.
Old Jan 22, 2006 | 08:20 AM
del-sol-95's Avatar
Default Re: zc swap oil problem (Honda Crx)
the oil filter is on but that is a good idea about the cleaner i appreciate it
Old Jan 22, 2006 | 08:32 AM
Honda Crx's Avatar
i would like to say i know a few things about these hondas.
Old Jan 22, 2006 | 09:21 AM
beyondspexj's Avatar
also check the oil pressure sensor above the oil filter and make sure the valve cover gasket isnt ripped.
baboracus
Aug 5, 2006 08:43 PM
Got_soy
Dec 22, 2005 08:20 PM
Stuartz
Oct 7, 2005 07:56 AM
muskrat
Oct 1, 2002 01:21 PM
muskrat
Sep 11, 2002 12:29 PM
