FS:(Part 1)B16a and B18b engine parts (MUST SEE!!!)
ok i have alot of parts for sale off of a 94 jdm b16a, 94 b18b and 95 b18b they are almost worthless to me. i have a price beside them because i have to but shoot me an offer. ok here goes...before you read more im from canada so we can work something out for shipping
1994 integra ls fuel rail with stock injectors and fpr $50obo
1994 integra wiring harness that has the alternator wire part cut off. i figured this is good for the plugs and maybe injector harness only. you might be able to fix it $30obo
1995 integra ls fuel injectors $40obo
1994 jdm b16a fuel injectors $50obo
94 integra heat sheild $10
1994 jdm b16a pressure plate. some hot spots ~100k $25obo. resurfaced/machined for $50
1994 jdm b16a clutch disc from pressure plate above. looks like it has some life left. never slipped when i had it $10obo
dont know what the name is. off a 94 integra - $10obo
94 integra oil sump - $15obo
1994 jdm b16a open stock diff $25obo
95 integra head shield $10
95 integra wiring harness that has been cut here. injector clips and every other plug is still on. $20obo
95 integra crank pully $10
94 integra valve cover with newer gasket $50obo
94 integra head bolts $15
95 integra head bolts $15
95 integra cams, plates gear etc. everything in picture $50obo
$15
94 integra throttle body. both of the sensors are cracked so they probably wont work. selling just for the housing if anyone wants it, but the sensors will be on it $10
94 integra flywheel $10. i can get it machined so it will look brand new and then ill sell for $50
94 integra ls head. said to have held 150-160psi but i dont believe it. sold as is and probably needs a rebuild $40
94 integra stock exhaust manifold $10
i also have a 94 b16a short block that is stripped of all sensors. it has CRACKED RING LANDS ON 2 OF THE PISTONS. will need new pistons and bearings. sleeves are in great shape. i would have taken pics tonight but that battery went dead. im keeping the vtec head becuase its almost mint. ill take pics if someone is interested. $75.00obo for the shortblock
$15
blubberbutt
Oct 4, 2003 07:09 PM
zilverz
Oct 14, 2002 04:30 PM
