spacer on BSQ mounting kit is corroded..
Old Jan 21, 2006 | 10:36 PM
reno96teg's Avatar
Default spacer on BSQ mounting kit is corroded..
i was doing some work on the integra when i noticed the following:
the spacer on the passenger side is fine. nothing else seems to be affected, and everything is still solid and in place. i guess i'll have to go in and replace that one of these days...
has anyone else experienced this?
Old Jan 22, 2006 | 12:05 AM
gsrious's Avatar
****, that spacer is toasted.
Old Jan 22, 2006 | 12:16 AM
RicharDC4's Avatar
Default Re: spacer on BSQ mounting kit is corroded.. (reno96teg)
replace it with beaks
(shamless plug for my used Beaks kit $40)
Old Jan 22, 2006 | 07:28 AM
reno96teg's Avatar
Default Re: spacer on BSQ mounting kit is corroded.. (RicharDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">****, that spacer is toasted.</TD></TR></TABLE>
yeah, man. i guess salt + aluminum = that??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicharDC4 &raquo;</TD></TR><TR><TD CLASS="quote">replace it with beaks
(shamless plug for my used Beaks kit $40) </TD></TR></TABLE>
i considered it for a second, but i've had this BSQ kit in there for just over 3 years. wow, how time flies.. if this is the worst problem after 3 winters and 3 years of throwing this thing around, it's no problem at all. i think i'll opt for spending a couple of bucks on a new spacer.
Old Jan 22, 2006 | 07:53 AM
VN712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reno96teg &raquo;</TD></TR><TR><TD CLASS="quote">yeah, man. i guess salt + aluminum = that??
I thought aluminum doesn't rust. It doesn't look corroded to me..more like barreling affect. Looks like crap regardless
Old Jan 22, 2006 | 08:29 AM
reno96teg's Avatar
Default Re: spacer on BSQ mounting kit is corroded.. (B20ZLS)
doesn't rust, but it can corrode, i think. maybe i tightened it too much, i don't know.. but i'm pretty sure i didn't. right side is fine and i'm **** about not over- nor under- tightening anything.
i'm more so wondering if anyone else experienced this. either way, it's not a big deal. it will be easy enough to replace.
Old Jan 22, 2006 | 12:19 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20ZLS &raquo;</TD></TR><TR><TD CLASS="quote">I thought aluminum doesn't rust. It doesn't look corroded to me..more like barreling affect. Looks like crap regardless </TD></TR></TABLE>
corrosion is rust, aluminum rust but its rust is white and not red light other metals. i just learned this too, from working in the sand blasting feild for awhile you find out all sorts or weird things about metals
Old Jan 22, 2006 | 08:38 PM
reno96teg's Avatar
Default Re: spacer on BSQ mounting kit is corroded.. (projectTeG)
^ well, there you go.
Old Jan 23, 2006 | 05:13 PM
VN712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
corrosion is rust, aluminum rust but its rust is white and not red light other metals. i just learned this too, from working in the sand blasting feild for awhile you find out all sorts or weird things about metals</TD></TR></TABLE>
Cool, I guess when Al oxidize, it produces that white residue. Learning something new everyday.
Old Jan 23, 2006 | 10:17 PM
95 integra's Avatar
BTW for what ever reason the drivers side of my car always gets more crap on it then the passenger side. Dont know if it has to do with the slope of the roads or what, but thats the way it is.
Old Jan 23, 2006 | 11:16 PM
Erik95LS's Avatar
Default Re: spacer on BSQ mounting kit is corroded.. (95 integra)
I've had mine in for almost 6 years now and have had no issues whatsoever. All components still in great shape and I check it all fairly often. My winters aren't as heavy as yours though.
I agree with you though, if thats the only problem you've had with it after 3 years thats darn good.
Old Jan 24, 2006 | 12:08 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20ZLS &raquo;</TD></TR><TR><TD CLASS="quote">Cool, I guess when Al oxidize, it produces that white residue. Learning something new everyday. </TD></TR></TABLE>
yup i found this out when my alternator bolt seized inside my alternator.
Old Jan 24, 2006 | 02:43 PM
vtecmissle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">BTW for what ever reason the drivers side of my car always gets more crap on it then the passenger side. Dont know if it has to do with the slope of the roads or what, but thats the way it is.</TD></TR></TABLE>
same around here but my passengers side gets washed real well from standing water on that side. Always clean underneath on the pas side. Drivers side usually nastier.
Old Jan 24, 2006 | 02:46 PM
lak8's Avatar
just use normal washers, works the same.
CRAZY-EG9
Apr 14, 2008 07:12 AM
GranadaTeg
May 6, 2006 11:29 PM
raphiael
Jul 11, 2004 09:39 PM
808State
12
Feb 3, 2004 10:55 PM
Kidnkorner
28
Jan 12, 2004 03:39 PM
