brakes, the fluid, leaks.. need help. simple stuff...
i had a problem with my brake fluid before... "evaporates" which i doubt. anyway, somebody correct me if i am wrong, but if you're leaking from after the brake master cyclinder (hardlines, hoses, etc...) you should be able to feel it in the pedal correct? it should become mushy because the fluid is no longer pressurized since there is a hole.
on the other hand... if you're leaking from the brake master cyclinder (as i was before) i never felt any difference in my pedal (ie: softer or firmer). my plastic resevoir was cracked.
if the leak is small like a wheel cylinder seaping you wont feel it untill you run the master dry. Berake fluid doesn't evaporate
OzzieAccord
Jan 30, 2003 12:39 PM
