1991 integra...check engine light on. help!!!
sup all...i'm actually postin this for a homie of mine he's on the road right now & is having a lil bit of problem.
so the car in question is a '91 integra(ls). ok, so he is on the freeway...at about a little over 4k rpm & the rpm's suddenly(slightly) to about 3k, i believe he said...
he says it retured real quick & he really didn't notica any power decrease, but his check engine light came on & is now on. he pulled over, poked around a lil...started the car and it has been runnin fine but the light is still on. like i said he is on the road(freeway), so if anyone can help or may have an idea of what is occuring, we'd appreciate it much.
tia. peace.
tia. peace.
well one thing you can you is find out how many times the check engine blinks but you first have to play around the obd2 plug.. well when you count how many times it blinkswhich will be a low blink.. then after that it blinks fast the last couple of time so same it blink 7 time then faster the last 3 time that mean you need to look under # 73 = in your manual and under the number of times it blinks it will tell you what is going on with the car
KrenzyRyan
33
Aug 1, 2007 03:08 PM
