how to pull codes on an 89 civic Si with D16Z6 swap???
Old Jan 21, 2006 | 07:51 PM
WolfGod's Avatar
Default how to pull codes on an 89 civic Si with D16Z6 swap???
how do i pull codes on a 1989 civic Si with a D16Z6 swap? i cant find the plug im supposed to use O_o
Old Jan 21, 2006 | 08:52 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: how to pull codes on an 89 civic Si with D16Z6 swap??? (WolfGod)
should be under the passenger dash eather a blue or gray 2 pin plug.
Old Jan 21, 2006 | 09:04 PM
WolfGod's Avatar
Default Re: how to pull codes on an 89 civic Si with D16Z6 swap??? (DieMaster)
that's what i've been told, but i cant find one anywhere, is there any other way?
Old Jan 21, 2006 | 11:09 PM
cmyrex's Avatar
did u use a jumber harness they should have 2 wires u hold together and get the codes!!!! goodluck
Old Jan 21, 2006 | 11:13 PM
WolfGod's Avatar
Default Re: how to pull codes on an 89 civic Si with D16Z6 swap??? (cmyrex)
i just bought the car like two weeks ago.. has what looks like an adapter harness or somethin for the ecu.. is that the one your refering to?
Old Jan 22, 2006 | 03:50 PM
WolfGod's Avatar
bump
Old Jan 22, 2006 | 03:53 PM
WolfGod's Avatar
im gonna take a pic of everything in the passenger side tomorrow so maybe you guys can help me out a bit more seeing what i see
Old Jan 22, 2006 | 03:59 PM
DieMaster's Avatar
<U>1989</U> i'm sorry i missread. the plug your looking for is a yellow caped plug on the fender wall drivers side. its between the shock and the window washer fluid tank under the hood.
Old Jan 22, 2006 | 07:59 PM
WolfGod's Avatar
awsome! thank you im gonna go check right now
Old Jan 22, 2006 | 08:38 PM
WolfGod's Avatar
i dont have that plug either, what the hell!!
are you sure that's where its supposed to be? or do you know the wire colors? maybe the guy who owned it before me just cut the connector off
Old Jan 22, 2006 | 08:43 PM
WolfGod's Avatar
does it make a diffrence if it's a hatch? just wondering... there isnt anything i can do at the ecu is there? it's a P28 chipped with S200 hondata... i dont have datalogging so i cant read them that way and i cant afford the upgrade right now
Old Jan 22, 2006 | 09:53 PM
cr-x-91's Avatar
call the guy back and ask if he ever hooked up some kinda yoggle swith for the codes.make sure u have a 4-wire 02 sensor and a z6 distributer.on the jumper harnes at the ecu, there should be a piggyback one that goes through ur firewall for the vtec wires,o2 wires,and some kinda toggle swith wires.
Old Jan 29, 2006 | 11:57 AM
cmyrex's Avatar
Default Re: (cr-x-91)
if you havnt figured it out the harness should have a sub harness going into the firewall there should be a yellow andblack wire if the jumper is from locashracing hold them together
Old Jan 29, 2006 | 12:18 PM
WolfGod's Avatar
Default Re: (cmyrex)
i dont see any wires going through the firewall but i'll check in a few minutes...
Old Aug 9, 2008 | 08:31 PM
JeffTheTinter's Avatar
I got a 89 civic LX 4 dr witha d15b8 motor, engine light keeps coming on after about 10 min of driving and dude said it was the speedo cable but that didnt work, i need to figure out how to get the codes also. Let me know if u got anything u can help me on. Thanks
Modified by JeffTheTinter at 9:36 PM 8/9/2008
Old Aug 9, 2008 | 08:38 PM
well i think i might have found how to pull codes, http://www.troublecodes.net/honda/ try that but its not gonna work for me cuz nothing is seeming wrong the light just comes on and idk why
ninty1civic
Nov 11, 2009 11:33 PM
A-busive
Oct 24, 2007 04:48 PM
rollindelsol
27
Dec 11, 2006 04:59 AM
K2e2vin
May 17, 2006 04:52 PM
SOHC_Brian
Jan 1, 2004 11:22 AM
