my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
Old Jan 21, 2006 | 06:33 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
it all started with a leaking master cylinder. then i replaced that, and found out the slave was also gone, so i replaced that. after that, i took it for a drive and it was fine for around 5 minutes, then it had to be forced into gear, and would shake while in gear with the clutch fully down and the car at a stop. one of my friend recommended to take out the tranny and replace the throw out bearing. come to find out the throw out bearing was totally gone, and i replaced it and poured mth fluid in it. took the car out for a drive, had to be around 30-40 minute drive, everything was perfect. couple days later, i'm starting to have the same problem, it would have to be forced into gear after 5 minutes into the drive. so i thought it was the slave, since the slave was bought used and was from a 10 yr old car. replaced it and still having the problem. PLEASE HELP ME, IM BEGGING YOU!!! i'm so fustrated right now....
Old Jan 21, 2006 | 06:54 PM
speedworks's Avatar
Default Re: my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!! (candy eg)
have you rebled the system. occasionally i get one that has to be rebled the next day, especially if you have a hard time bleeding it the first time. try that
Old Jan 21, 2006 | 06:58 PM
candy eg's Avatar
Default Re: my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!! (speedworks)
how would i "reble" it? thx for responding.
Old Jan 21, 2006 | 07:31 PM
jlperformance's Avatar
He is not saying "reble" he is saying rebled meaning to "re-bleed" it. Some times a day or two later you may have to do this, it has happened to me a few times.
Old Jan 21, 2006 | 07:46 PM
candy eg's Avatar
yea i keep bleeding it over and over, but it sooner or later comes back again...
Old Jan 21, 2006 | 11:53 PM
SFWD 1934's Avatar
Just out of curiosity is this in a car with a swap? (I.E. an EG with a GSR motor/trany). I have seen it before where guys will get a new master cylinder for the Civic from the auto parts store, but fail to remember that they are not running the stock parts. I have experienced that more with cars that have high performance clutches in them. Other than that, it could be the pressure plate, or it could be a bad rubber line or hard line that has a leak in it allowing air to get back into the system.
Jason
Old Jan 22, 2006 | 04:02 AM
candy eg's Avatar
Default Re: my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!! (SFWD 1934)
yes it is in a car with a swap. eg with b18c1 and upgraded clutch. i did replace the master cylinder with one from a 95 ex coupe. you think i should change it to gsr one?
Old Jan 22, 2006 | 08:20 AM
Used2beAb16's Avatar
seems like you got a leak somewhere
Old Jan 22, 2006 | 09:52 AM
candy eg's Avatar
hmmm, i checked for leaks, i cant seem to find any, and the fluid stays at the same level in the resevoir.
Old Jan 22, 2006 | 01:32 PM
SiKnezzALLmotor's Avatar
didi u try checking your clutch slave >>>??often times it fails and check for leakage
Old Jan 22, 2006 | 02:01 PM
candy eg's Avatar
Default Re: my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!! (SiKnezzALLmotor)
yes, i replaced it with a brand new oem one.
Old Jan 22, 2006 | 02:07 PM
h22 civic's Avatar
did u use factory lines or braided lines?
Old Jan 22, 2006 | 06:02 PM
candy eg's Avatar
Default Re: my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!! (h22 civic)
they're factory
Old Jan 23, 2006 | 08:02 AM
candy eg's Avatar
bump for any other insight
gsr_b20b
Jul 17, 2009 03:53 AM
517vwj_boi
Mar 14, 2006 09:35 PM
candy eg
Jan 25, 2006 06:41 AM
candy eg
Jan 23, 2006 09:56 AM
candy eg
Jan 23, 2006 08:02 AM
