my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
Old Jan 21, 2006 | 06:32 PM
candy eg's Avatar
From: The Real O.C. Oakland Chinatown, California, USA
Default my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
it all started with a leaking master cylinder. then i replaced that, and found out the slave was also gone, so i replaced that. after that, i took it for a drive and it was fine for around 5 minutes, then it had to be forced into gear, and would shake while in gear with the clutch fully down and the car at a stop. one of my friend recommended to take out the tranny and replace the throw out bearing. come to find out the throw out bearing was totally gone, and i replaced it and poured mth fluid in it. took the car out for a drive, had to be around 30-40 minute drive, everything was perfect. couple days later, i'm starting to have the same problem, it would have to be forced into gear after 5 minutes into the drive. so i thought it was the slave, since the slave was bought used and was from a 10 yr old car. replaced it and still having the problem. PLEASE HELP ME, IM BEGGING YOU!!! i'm so fustrated right now....
Old Jan 22, 2006 | 08:15 AM
IMALLSLO's Avatar
Default Re: my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!! (candy eg)
Rebleed sthe system.....good. Try this and see if it helps. Seems like your having hydro pressure issues not the clutch.
Old Jan 22, 2006 | 09:59 AM
candy eg's Avatar
but everytime i get in the car, it'll work fine for about 5 minutes, then start to get rough and i have to force it to put in gear.
Old Jan 22, 2006 | 12:24 PM
candy eg's Avatar
bump
Old Jan 22, 2006 | 07:33 PM
Hatch Heaven's Avatar
I say rebleed the system cause you might still have a air pocket/bubble some where in the system......
Old Jan 22, 2006 | 08:00 PM
candy eg's Avatar
Default Re: my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!! (Hatch Heaven)
what way is the "proper" step by step way to bleed a it?
Old Jan 22, 2006 | 08:43 PM
press the clutch pedal and hold then the other person helping you will release the bleeder screw.....keep doing it until a steady stream of fluid comes out
Old Jan 23, 2006 | 08:02 AM
candy eg's Avatar
bump for any other insight
gsr_b20b
Jul 17, 2009 03:53 AM
candy eg
Jan 25, 2006 06:41 AM
candy eg
Jan 23, 2006 09:56 AM
candy eg
Jan 23, 2006 08:02 AM
TKL
14
Nov 11, 2004 09:27 AM
