my clutch/tranny is giving me problems, PLEASE HELPPPPP!!!!!
From: The Real O.C. Oakland Chinatown, California, USA
it all started with a leaking master cylinder. then i replaced that, and found out the slave was also gone, so i replaced that. after that, i took it for a drive and it was fine for around 5 minutes, then it had to be forced into gear, and would shake while in gear with the clutch fully down and the car at a stop. one of my friend recommended to take out the tranny and replace the throw out bearing. come to find out the throw out bearing was totally gone, and i replaced it and poured mth fluid in it. took the car out for a drive, had to be around 30-40 minute drive, everything was perfect. couple days later, i'm starting to have the same problem, it would have to be forced into gear after 5 minutes into the drive. so i thought it was the slave, since the slave was bought used and was from a 10 yr old car. replaced it and still having the problem. PLEASE HELP ME, IM BEGGING YOU!!! i'm so fustrated right now....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 »</TD></TR><TR><TD CLASS="quote">Sounds like a clutch problem. Im guessing a damper spring on the disk popped out.</TD></TR></TABLE>
i agree. sounds like a clutch problem. you basically replaced everything else.
candy eg
Jan 25, 2006 06:41 AM
candy eg
Jan 23, 2006 08:02 AM
candy eg
