obd1 b16a to b18c
I am pretty sure the motor mounts (if you have Hasport) are a little different, the B18 will sit higher than it would if you use the right GSR mount kit and may be too high to shut your hood? not sure though (check with Hasport or whatever company your mounts are from), aside from the ECU and maybe an electric plug or two it will drop right in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heyitzspikey »</TD></TR><TR><TD CLASS="quote">i have the advid mount and shift linkage and can i still use the same shaft as the b16a?</TD></TR></TABLE>
Do you mean Axle??? if so then yes they will work
spcrxracer
12
Sep 23, 2004 08:27 PM
handa
16
Apr 28, 2004 01:43 PM
