where to buy washers
Old Jan 21, 2006 | 12:09 PM
chrisw85's Avatar
Default where to buy washers
i figured that washers would fall under fabrication (but if not feel free to move), but they aren't your typical washers.
I'm lookin for either alum or copper 3/8" i.d. or 10mm i.d. washers, commonly used for sealing the banjo bolts on brake systems. MCMaster doesn't have them; the o.d. is too big at 7/8ths.
I.D: .3750 in +/- .010
O.D: .5625 in +/- .010
Thickness: .030 in to .050 in
material: copper or aluminum.
I know you can buy these at the dealer (at $1.50 a pop) or specialtly shops, but I want to know where to purchase in bulk, quantities of 100 w/o needing a comercial account. Where do companies that make ss lines, big brake kits, etc buy them from?
Thanks in advance.
Old Jan 22, 2006 | 12:49 PM
chrisw85's Avatar
Default Re: where to buy washers (chrisw85)
http://www.denniskirk.com/jsp/...MC394 thats the cheapest i've found a 10 pack of [goodridge] copper ones.
http://www.cbxmanmotorcycles.c....aspx thats about the cheapest I've found for aluminum ones.
or
http://www.bakerprecision.com/statseal.htm for the Earl's kind; essentially the same thing.
note that these are all retail prices; i'm sure bulk qty are less expensive.
http://superior.thomasnet.com/...ter=0 this place manufacturers washers. They're a little thin compared to Goodridge's .050 spec.
Old Jan 24, 2006 | 09:25 AM
LBHgti's Avatar
Techna-fit 310-212-5051
Tennobanzai
Suspension & Brakes
Dec 5, 2012 09:06 AM
RI_TM
Apr 13, 2005 08:11 AM
Quik Chris
Sep 5, 2004 08:39 PM
beeboyee
Apr 8, 2002 11:53 PM
