integra not starting...long story
i have a b18c1 with a completely stock bottom-end. the head was rebuilt with all new seals, guides, itr valves, portflow dual springs and retainers, stock gsr cams and gears. basically everything in the head is new. also have i/h/e and carsound cat. bolted everything together about 4k miles ago. about 100 miles ago car stalled out and wouldn't get spark. i had a brand new distributor for it laying around swapped it and ran perfectly for another 50 miles or so.
driving on the highway the car bogged and stalled. i stopped and restarted the car and when i popped the hood and there was small amounts of white smoke steadily coming from the intake, oil breather, and underneath the intake manifold(possibly pcv or oil box? not sure) i had the car towed home thinking the head gasket was shot or rings. i drained oil and coolant and both are normal. pulled the plugs and there's no oil deposits, they look a little rich but nothing extreme.
I tried to restart the car and just cranks with no spark. checked all the grounds/wiring/fuses, same thing. i would think it would be just a distributor/ignition issue but i'm not sure with the white smoke. if this happened to anyone else or any ideas; please let me know...thanks in advance
any ideas or should i just troubleshoot the no spark as usual? i've had my share of distributor issues in my years with honda(s) but i've never had any smoke involved...thanks again
imbest123
Mar 20, 2011 06:56 AM
ITLNstallion818
Nov 5, 2008 05:32 PM
EF9 JAMS!!!
Jan 5, 2006 12:43 PM
