k20 in a civic? how hard
Old Jan 21, 2006 | 10:32 AM
Timmyflys's Avatar
Default k20 in a civic? how hard
i really wanted to do a k20 in a civic hatch any suggestions on anything how hard is it what all do you need hard to wire up? what year civic would be best to put it in or easiest?
Old Jan 21, 2006 | 10:36 AM
HATCHingMN's Avatar
Default Re: k20 in a civic? how hard (Timmyflys)
not hard but runs you about $8K-10K
goodluck
Old Jan 21, 2006 | 10:41 AM
nighttrain33's Avatar
Talk to litterbox. Done it and so far everything has run all right. Oh, and K20.org and search are good tools as well.
-Shane
Old Jan 21, 2006 | 11:33 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: k20 in a civic? how hard (nighttrain33)
http://www.k20a.org/forum/showthread.php?t=4083
Old Jan 22, 2006 | 06:23 AM
EKhybrid's Avatar
Default Re: k20 in a civic? how hard (litterbox)
The only thing hard about the swap is on your WALLET! Big bucks. Getting the motor in is a bit of a challenge. If you've done a B-series swap, then this is no different. There are a lot of parts that need to be purchased and I recommend that you have all of them before attempting to perform this swap. There are plug and play harnesses out there so wiring isn't an issues. If you're swaping a k20 into an EK, I recommend the EG crossmember w/matching LCA's and steering rack. Gives the motor more ground clearance and straighter axles.
NinjaX_X
K Series
Oct 13, 2018 09:16 AM
run for cover
Jun 21, 2010 08:31 PM
Brazilian_VTi
May 16, 2006 12:41 PM
azn-vk
Jul 11, 2005 12:12 AM
kart_46
Jun 2, 2003 01:16 PM
