ECU storing highest RPM reached?
Old Jan 21, 2006 | 09:38 AM
Patron's Avatar
Default ECU storing highest RPM reached?
I own a 04 Si, does anyone know if the ECU stores the highest rpm reached? If it does, how long does it store it for? Just to squelch speculation now, I'll tell you that I did not do anything to the motor or overrev it. I just want to know if it has some kind of memory. Thanks.
Old Jan 21, 2006 | 12:12 PM
SpoonyDC5's Avatar
Default Re: ECU storing highest RPM reached? (ptran13)
normally yes so if you blow up your car the dealership can look into it and tell if its legit or not... it can bring up latest shift points and RPM's i believe, to help honda in monitoring warrantee "fraud" i guess you could say
Old Jan 21, 2006 | 01:36 PM
Patron's Avatar
Default Re: ECU storing highest RPM reached? (SpoonyDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonyDC5 &raquo;</TD></TR><TR><TD CLASS="quote">normally yes so if you blow up your car the dealership can look into it and tell if its legit or not... it can bring up latest shift points and RPM's i believe, to help honda in monitoring warrantee "fraud" i guess you could say </TD></TR></TABLE>
Thanks! Do you know how long it stores info for? What else does it monitor? Does it monitor various sensors like knock and timing?
Old Jan 21, 2006 | 02:49 PM
Ross 2.0's Avatar
In a Junkyard near you.
The ECU doesn't store the info unless it needs to (if a trouble code is set) However there is a DTC for High rev (no check engine light) It sets if the car is run at very high rpm's for more than a minute.
Old Jan 22, 2006 | 12:14 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 &raquo;</TD></TR><TR><TD CLASS="quote">I own a 04 Si, does anyone know if the ECU stores the highest rpm reached? </TD></TR></TABLE>
When a trouble code is stored the ecu saves the engine parameters at that time. We had an s2000 come in with a dropped valve, the freeze data showed the rpms at 11,400. Warranty didn't cover the repairs.
Old Jan 22, 2006 | 12:15 PM
Chiovnidca's Avatar
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote"> However there is a DTC for High rev (no check engine light) It sets if the car is run at very high rpm's for more than a minute.</TD></TR></TABLE>
Really? What is the code?
MaiSi
Audio / Security / Video
11
Sep 4, 2008 02:38 PM
2Fast4Everyone
19
Jul 26, 2007 02:33 PM
Civic138
10
Jun 27, 2007 02:23 AM
.Grimace
Nov 30, 2006 12:59 PM
riceball777
Jun 4, 2003 09:46 AM
