clutch Q:
Old Jan 21, 2006 | 09:29 AM
No2Pencil's Avatar
Default clutch Q:
-stock- 90' crx HF b16a1 lsd obd-0
it all started a couple of days ago. i was in a McD's drive thrue when my clutch cable started to loosen. after i adjusted it, it would keep sliping more and more often. one of the last times i adjusted it the car wouldn't start, i have power... and its still wont start...
-i have tightend it fully
-i have loosend it fully
-the pedal has tension when tightend
i ordered a new cable just in case but i doubt thats the prob now, or is it? help thanx.
Old Jan 21, 2006 | 12:49 PM
old man neri's Avatar
Default Re: clutch Q: (No2Pencil)
check the little safty switch by the clutch pedal. Maybe in all your tightening it might have moved the pedal down a bit. or perhaps the pedal is just not returning all the way. Can you lift it up with your foot?
Old Jan 21, 2006 | 01:05 PM
thesmogman's Avatar
Could be's
Throwout bearing
release arm
Clutch pedal (Itself)
Mounts for the cable
cable
You mentioned the car won't start. You have a clutch position switch on the pedal assembly This sw won't let you start the car without pressing the clutch in. Somehow you messed it up. I love to work under dash's don't you?
Good luck
Old Jan 22, 2006 | 11:35 AM
No2Pencil's Avatar
Default Re: clutch Q: (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">Could be's
Throwout bearing
release arm
cable
Good luck</TD></TR></TABLE>
hit the nail on the head starts up fine now... some how the pedal didnt reach
Chi925
Transmission & Drivetrain
Jan 31, 2012 05:55 PM
EG6[B16A1]
Dec 15, 2005 09:31 AM
Jonathan_ED3
Aug 14, 2004 10:25 AM
iridebiketrials
Dec 5, 2003 10:05 AM
91HATCH
Jan 9, 2003 12:06 PM
