94 Accord LX Problems?
the following problems with the car :
1.The clock does not work and cig outlet( what fuse or relay is this?)
2. The car over heats after a few min of driving. when the A/C is put on the car does not over heat(the fans kick in). can this be a relay ??? i changed the thermastat.
3. The fuel gauge comes on and off . ( do i need a new cluster?)
The car has 159,xxx
4 door
everything is stock. (never been raced)
The car has 159,xxx
4 door
ok i tried changing the relays by the fan and it worked with no problems. but then after a few min gone by the relays burned out again and the car began to over heat. can the fans be the problem ? what can cause this?
you are drawing too much current. your fan might have a lot of resistance to turning (bearing gone bad) in it causing it to draw more current and cooking your relay.
so i should change the fans?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">you are drawing too much current. your fan might have a lot of resistance to turning (bearing gone bad) in it causing it to draw more current and cooking your relay.</TD></TR></TABLE>
peacexisxfree
Jan 19, 2014 01:29 PM
amymedders
Jul 24, 2010 12:28 PM
aws140
Sep 5, 2005 04:11 AM
