First gen acting strange!
Old Jan 21, 2006 | 06:28 AM
superbeastcrx's Avatar
Default First gen acting strange!
hey my first gen si crx is acting wierd. it started about three days ago. i was leaving a light, and once i shifted into third my car started to cut out, but if i rev it up and then shift, it stops cutting out. last night i checked my oil when i got home and noticed that my header was glowing red! i think it my fuel pump going out or my fuel filter going out. tell me what u think any help will be greatly appriacted. thanks in advance
J.D.
Old Jan 21, 2006 | 07:11 AM
shadycrx's Avatar
Default Re: First gen acting strange! (superbeastcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbeastcrx &raquo;</TD></TR><TR><TD CLASS="quote"> last night i checked my oil when i got home and noticed that my header was glowing red! i think it my fuel pump going out or my fuel filter going out</TD></TR></TABLE>
not sure how you tied those 2 things together but why not replace the fuel filter so you can deffinitely rule that out at least
Old Jan 21, 2006 | 07:30 AM
blah13's Avatar
Default Re: First gen acting strange! (shadycrx)
Wow, super hot EGT's. Does sound like a lack of fuel, I'd change the filter anyway if you havent done so in a while but usually a clogged filter = sputtering in higher rpms. Also check your coolant and spark plugs. Maybe run a 1 step colder plug to help until you can figure out the cause.
Old Jan 21, 2006 | 07:46 AM
Default Re: First gen acting strange! (blah13)
what's wierd is my car is staying real cold like it has always has, and the header is glowing red! i'm scared i'll catch my rex on fire!
Old Jan 21, 2006 | 01:17 PM
blah13's Avatar
Actually check your plugs first. If they seem fine then unbolt your cat, a clogged cat can cause the header to glow. It may be loud as hell but drive it until your header would normally start glowing and check. Also when you unbolt the cat notice if the performance gets better. What kind of gas mileage have you been getting?
Old Jan 21, 2006 | 05:19 PM
justingreat's Avatar
the cat on those engines is right up top just barely after the header runners. it is common for the cat to get plugged from oil and unburnt fuel. my 84 did the same stuff...
Old Jan 23, 2006 | 07:23 AM
Default Re: (justingreat)
my cat is empty , and i have 2 3/4 exhaust from th down pipe back.
Old Jan 23, 2006 | 07:50 AM
crx_88_si's Avatar
glowing red could also be a sign of too rich. check fuel pressure.
Old Jan 23, 2006 | 07:59 AM
i'm getting 46.5 MPG! i ordered th eparts to do a tune up, Cap, rotor, pugs, wires, i'll get a new fuel filter after work to day just to be safe.
9thgenidiot
Apr 21, 2024 08:20 AM
ExVtec
Honda S2000
Feb 2, 2009 12:12 PM
Xenobi
Jan 26, 2006 09:24 PM
crispvtec98
Jul 5, 2005 03:20 PM
Kack
Dec 10, 2003 02:19 AM
