can you determine 1/4 mile by 1/8 mile time?
Old Jan 20, 2006 | 10:49 PM
z6's Avatar
z6
Default can you determine 1/4 mile by 1/8 mile time?
if someone has an 1/8 mile time but not a 1/4 time, is there any way to estimate/determine there 1/4 mile?
Old Jan 20, 2006 | 10:53 PM
dunkd's Avatar
sorta? post some numbers and car setup and we'll guess
Old Jan 21, 2006 | 01:00 PM
SiKnezzALLmotor's Avatar
Default Re: (dunkd)
nope cause driver error might effect time for instance u mishift
Old Jan 21, 2006 | 01:34 PM
KaoticSnow's Avatar
na, My car dosnet really start pulling hard untill 3rd gear. I find that when I race cars that are right at my level I usually lag behind untill I hit 3rd then I start pulling on them. I have some friends that pull hard off the launch and not as hard later on in the run. it all depends on the car.
Old Jan 21, 2006 | 01:49 PM
SilCiv2K's Avatar
Default Re: (KaoticSnow)
its a bit easier with a n/a but good luck with a boosted car as you have no idea what type of powerband it has. The power is consistent in NA applications so you could actually guesstimate the 1/4 based on the 1/8 60ft 330 ET/MPH. Again I am not saying you would know the exact time but it will land you there -/+.2 based on the factors I mentioned.
Old Jan 21, 2006 | 04:12 PM
91' LS-VTEC's Avatar
Default Re: can you determine 1/4 mile by 1/8 mile time? (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">if someone has an 1/8 mile time but not a 1/4 time, is there any way to estimate/determine there 1/4 mile?</TD></TR></TABLE>
Post your 1/8 mile time, along with your set-up, car,weight,tires,ect.
And I'm shure well give you a good "guesstamant" of what it "might" run.
Old Jan 22, 2006 | 12:25 PM
chriskey0829's Avatar
General rule of thumb is to take your 1/8 mile and multiply that by 1.55. But remember, we drive FWD cars and we are lighter than other cars. As someone said before, it is harder to ESTIMATE your time if you have a turbo or nitrous. But x1.55 will give you a close estimate.
Old Jan 22, 2006 | 04:27 PM
TeamNextGenChris's Avatar
http://www.velocidad-maxima.co...ators
as said above,this is only an estimate.there are many variables.
Chris
Old Jan 24, 2006 | 01:47 PM
B18 CYA's Avatar
i just tryed it compares to some of my timeslips for example.
8th mile ET....8.7772x 1.55 = 13.6046...actual ET, 13.6030, and difference of .0016
8th mile ET 8.7948 x1.55=13.6319...actual ET, 13.6199, difference of .0120
pretty damn close if you ask me.
Old Jan 24, 2006 | 04:05 PM
Default Re: can you determine 1/4 mile by 1/8 mile time? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote"> http://www.velocidad-maxima.co...ators
Chris</TD></TR></TABLE>
thought I'd throw this up here also..maybe it will help eleminate some guess my 1/4mile thread...once again, just an estimant.
http://www.ultimateresourceguides.com/content/
1/4mile from HP & weight ^^^^
Old Jan 24, 2006 | 04:14 PM
Default Re: can you determine 1/4 mile by 1/8 mile time? (91' LS-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91’ LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
1/4mile from HP & weight ^^^^</TD></TR></TABLE>
that's a cool one too,although it seems very optimistic.according to it,my very mild street setup(around 450WHP.haven't weighed car lately,but i'm guessing 2400lbs) that i'm putting together should be good for VERY low 10 second,almost 9 second ETs
chris
Old Jan 24, 2006 | 06:51 PM
jdmturbosol's Avatar
Although those websites are great for estimates they do not take many of the most important variables into consideration when calculating times.
Old Jan 25, 2006 | 03:25 AM
Default Re: can you determine 1/4 mile by 1/8 mile time? (jdmturbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">Although those websites are great for estimates they do not take many of the most important variables into consideration when calculating times.
yeah,like total lack of traction,as in our cars
chris
Old Jan 26, 2006 | 10:44 AM
old guy's Avatar
NHRA has a conversion chart for 1/8 to 1/4 mile, but it's based on all motor, rear wheel drive cars. It's a little off when used for front wheel drive, because of the different 60 foots. But someone who's good with excel or something like that could probably make it work. It's way off for turbo cars, but again, someone could probably tweak it and make it work. This is likely the best starting point, since NHRA's been doing this kind of thing for "a while now".
I thought I had a copy of it, but I can't find it. Maybe someone at NHRA can fax a copy of it, and one you guys who are good with formulas could update it for FWD and turbos.
Steve Berman
Feb 7, 2005 07:52 AM
itralex
Aug 9, 2003 09:10 PM
brega3
Jun 26, 2003 10:05 AM
chillly
Nov 4, 2002 11:42 AM
Adi Radoncic
Sep 1, 2002 11:37 PM
