key off engine on ??
we just did a b16a swap in a friend 91 crx and i compared it to my other b16a swap on a 90 crx everything is the same but the 91 keeps running and you have to pull the dizzy power for the car to stop running. any clues on what went wrong????? all under dash wiring looks right and we changed the ignition switch it is like there is a constant always running
You have a short or a main power wire exposed?I had a similar problem before and it turned out to be my power cable from my rear mounted battery had been rubbing and was touching keeping the power live even after ignition shut off.
