over heating and NO HEAT !!!!!! please help!!!!
Old Jan 20, 2006 | 09:51 PM
speedhatch's Avatar
Default over heating and NO HEAT !!!!!! please help!!!!
ok we swaped a gsr with a b16 head into my eg hatch, everything is fine excpet that it over heats when u drive it, and theres no heat at all! the water pump is brand new and so is the thermosat. what else could it be?? PLEASE HELP!!
Old Jan 21, 2006 | 12:29 AM
Contender25
Guest
Posts: n/a
Might have air in the cooling system possible?, try bleeding some of it off with the bleeder valve, should be on the upper radiator hose bracket where it connects to the head.
Old Jan 21, 2006 | 12:36 AM
riceburnerryan's Avatar
also check the heater core hoses....
Old Jan 21, 2006 | 07:01 AM
speedhatch's Avatar
ok thanks, anyother tips?
Old Jan 21, 2006 | 11:15 AM
ekay. jay's Avatar
Default Re: (speedhatch)
Sounds like there is Air in the coolant lines, i would try to bleed all the air out first. Also make sure u have all the coolant hoses hooked up to were they are supose to be.
Old Jan 21, 2006 | 11:27 AM
Sasebonian's Avatar
Default Re: over heating and NO HEAT !!!!!! please help!!!! (speedhatch)
warped head maybe?
Old Jan 21, 2006 | 11:33 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: over heating and NO HEAT !!!!!! please help!!!! (Sasebonian)
bleed it, drive it, then bleed it again
Old Jan 21, 2006 | 04:35 PM
Swapped_EG's Avatar
bleed it of course then check the Thermostat. seems that everyone on thise forum forgets what they are.
Old Jan 21, 2006 | 04:44 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
did you put a new headgasket on?
Old Jan 21, 2006 | 04:46 PM
1SickEG's Avatar
my eclipse did it...thermostat
Old Jan 24, 2006 | 12:17 PM
speedhatch's Avatar
ya it turns out the thermostat was sticking inside the houseing. so its fixed, thanks everyone for your help!
Old Jan 25, 2006 | 02:43 PM
Swapped_EG's Avatar
How bout that. The easiest thing turns out to be the problem. Not tryin to be a dick head but some of the ppl amaze me on this forum. They look at the problem and always seem to go for the worst case scenario first thing. It seems that not too many ppl have a real job in this field. But its good that you fixed your problem.
Old Jan 25, 2006 | 07:19 PM
1baddcivicsi's Avatar
Default Re: (Contender25)
I blew a headgasket/cylinder-head while I had the same problem, undue the bottom radiator hose (when the motor is cool). Be careful its under-pressure, then connect the hose again and slowly,slowly,slowly pour the coolant where the radiator cap is without making air pockets in your radiator system, helps to use a funnel, pour some coolant in the resevior tank, turn the car on at idle with the radiator cap off u will watch as the coolant goes down, then refill it again and do that for a while. U will go through lots of coolant but u will save a headgasket if not much, much more! Make sure to monitor your temp gauge and check your radiator very often!
samuelriesterer
Dec 8, 2014 04:45 PM
MMMGIRL
Dec 9, 2013 03:20 PM
darkblackH2B
Dec 15, 2008 07:08 PM
Gvis420
Oct 21, 2007 05:42 PM
ThaSpitefulWun
Apr 5, 2004 09:17 AM
