headlights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey »</TD></TR><TR><TD CLASS="quote">isnt that normal
only both should stay on while your holding the lever back</TD></TR></TABLE>
That is how mine work, I actually would want the reverse but I hear a relay is needed. Sometimes it;s just so dark that I need all 4 light at the same time, are you sure you posted your question correctly??? If so then I think your car may be messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spazz0nater »</TD></TR><TR><TD CLASS="quote">ya, when i go to high beams all stay on. Its a 90 civic si hatch. The reason i want to is i have yellow bulbs for my highs</TD></TR></TABLE>
Somebody may have already added a relay to make yours do that. You will need to trace down the wires to see if they have been modified or tampered with.
i highly dought that, i have gone through the wireing and its clean. The prevoius owner was 3rd owner and they never did any thing to it. Its a very clean car and was very well maintained. But i will check the wiring.
Did you get your car from Canada? J/K
Sounds to me like the relay that clicks off your low beams when you put on your highs is messed up. I would switch it out, wherever it is. Do you mean low beams, as in fog lights?
no low beams as in when you just turn your lights on. and when i turn my high beams on they all stay on. And yes it does have a sticker on the the hood latch stating made in canada.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spazz0nater »</TD></TR><TR><TD CLASS="quote">no low beams as in when you just turn your lights on. and when i turn my high beams on they all stay on. And yes it does have a sticker on the the hood latch stating made in canada.</TD></TR></TABLE> same here
Hiroshima_VTi-S
13
Aug 21, 2006 09:29 PM
