SKUNK2 stage 2??????????? FOR 2000 GSR
Old Jan 20, 2006 | 08:40 PM
finest_GSR's Avatar
Default SKUNK2 stage 2??????????? FOR 2000 GSR
planning on getting the skunk2 valve springs and retainers...and stage 2 cams...people tell me that the lift on the stage two...will make the valve hit the piston(not enough clearance) i don't want to get new pistons anyways ..i know it needs to be well tune....but will it be safe...does it need more advance or retard on those cams...advice plz.....thankz
Old Jan 20, 2006 | 09:24 PM
JFG Kevin's Avatar
Default Re: SKUNK2 stage 2??????????? FOR 2000 GSR (finest_GSR)
I'm running that set up with CTR piston....tuned...runs fine all the way up to 9500rpm
Old Jan 20, 2006 | 10:15 PM
numberone's Avatar
I'm running a 97 gsr stock longblock with retainers and springs w/the stage 2 skunks, no problems whatsoever! Your peeps need to stop smoking and just sell the product.
Old Jan 21, 2006 | 12:59 AM
mattcivic's Avatar
Default Re: SKUNK2 stage 2??????????? FOR 2000 GSR (numberone)
i dont think u will have enough compression to run those stage 2 cams to there full potential. u might want to look into shaving yer head like 20 thous. and getting a 2 layer head gasket as well. some ITR or CTR pistons like the guy above is using would be a good plus as well. GL
Old Jan 21, 2006 | 11:05 AM
numberone's Avatar
Default Re: SKUNK2 stage 2??????????? FOR 2000 GSR (mattcivic)
I will have to agree, people told me that even though they ran fine on the stock long block, vtec should hit alot harder and that I need to bump up compression.
Old Jan 24, 2006 | 08:07 PM
finest_GSR's Avatar
how many degrees n (+ and -- ) r u tuning on both intake and exhaust.....how would u rank the cams????
Old Jan 28, 2006 | 06:13 PM
JFG Kevin's Avatar
you shouldn't mess with the cam gears...unless your a tuner yourself...if you are a tuner...you wouldn't be askin that question tho....you get my message?
Old Jan 28, 2006 | 06:21 PM
angelSIR-G's Avatar
if you look at the captions on some of the websites selling those cams it says that you have enough clearance as long as you don't get oversized valves.
msbhvn_DC2
Mar 8, 2006 08:11 PM
IggyBcool
16
May 14, 2005 05:57 PM
IggyBcool
May 14, 2005 01:56 PM
JinteDgraM
Mar 20, 2005 09:06 PM
99Sib16a2
Jun 22, 2004 09:46 AM
