look 4 piston calipers for 15" wheels big brake kit
http://www.streetrays.com/cata.../6429
11 inch rotors
http://www.streetrays.com/cata.../6416
11.75 inch rotors
Applications
96,97,98,99,00 Civic EX
90,91,92,93,94,95 Civic EX
Del Sol B16
90,91,92,93 Integra
99-2000 Civic Si
92,93,94,95 Civic Si w/ABS
94,95,96,97,98,99,00,01 Integra
Specifications
11.75" 4 piston kit
Description
The 11.75" 4 piston kit represents the pinnacle of braking for the sport compact cars. Using large 4 piston calipers with the 2 piece 11.75" rotors, this kit is the same basic design used by many championship-winning cars.
From the lightweight design to its durability under extreme conditions, this kit will provide your Sport Compact with all the brakes it could ever hope to use. Designed to fit under many 15" wheels, this package will help you lower those lap times and put you on the podium. You will notice the benefits of these monster rotors from the first time you hit the brakes, while the 4 piston calipers gives you more control while out-braking the competition.
Kit comes complete with all the parts for installation including: 2 piece 11.75" drilled and slotted rotors, large 4 piston calipers, performance brake pads, front braided steel brake lines or calipers adapter fittings, aluminum adapter brackets, bolt, etc.
NOTE: Due to the design of the Honda/Acura front suspension, lowering of the car more than 1.75" from the stock ride height will result in possible rotor to lower ball joint stud interference during extreme suspension compression
ive been looking for this for a while
this is the link i started from just scroll down
http://www.streetrays.com/cata...age/6
Modified by integra3586 at 9:25 PM 1/20/2006
Modified by integra3586 at 9:27 PM 1/20/2006
11 inch rotors
11.75 inch rotors
Applications
Del Sol B16
90,91,92,93 Integra
99-2000 Civic Si
Specifications
11.75" 4 piston kit
Description
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo »</TD></TR><TR><TD CLASS="quote">Finally, something for guys like me that insist on OEM rims.
I wonder how well they perform compared to the larger kits.</TD></TR></TABLE>
Welcome to 2001
do a search and you'll find your results
Welcome to 2001
modacar.com
Are these the same as the ones you have listed? Their only $710 from modacar.. The ones you show start at $1,225. They also fit under a 15
hey 12.2 are fine with me if they fit under atleast a 16" wheel, gives me room to go back to stock if i want,
$710 is pretty damn cheap i wonder if thats the whole kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob »</TD></TR><TR><TD CLASS="quote">i have this setup on my teg and had to run spacers. </TD></TR></TABLE>
what size wheels? stocks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 »</TD></TR><TR><TD CLASS="quote">
what size wheels? stocks?</TD></TR></TABLE>
gsr blades
gsr blades
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">http://fastbrakes.com/shop/pro...d=373</TD></TR></TABLE>
1994-2001 Integra 11 inch 4 piston kit with dust seals DC-DP11 $950.00
Click to enlarge
New 11 inch kit with 4 piston calipers using dust seals. This kit was designed to provide the hard street driver with the benefits of the 4 pot calipers with the ease of maintenance of the stock calipers. Kit comes with the 11 inch slotted & drilled rotors, 4 pot aluminum calipers with dust seals, performance brake pads, adapter brackets, and front braided steel brake lines. NOTE: This kit will fit some 15" factory alloy wheels with a 3mm wheel spacer. 1994-2001 Integra RS, LS, GS, GS-R
Click to enlarge
Or you could always try brembo blanks and axxis ultimate pads Do you want better braking? or something that looks good behind the wheel? Im curently running 11.1 inch prelude rotors and itr calipers up front and 11.5 inch 300zx rotors and a caliper relocator in the rear of my 91 civic si. Its waaaay overkill
fast email replies and quick service
LshatchTurbo
Oct 3, 2001 08:07 AM
