what's the procedure to paint a bodykit?? first try, help pls
i am about to paint my WW RS bodykit myself.
just have no clue about how to start. never done body works before.
the kit is made by fiberglass i guess.
what should i do? how can i do a good job?
what should i do for the prep? do i have to sand it?
then paint it, and apply clear coat?
is that all?
please give me some idea, a little more detail would be the great.
thanks a lot!!!
is that all?
thanks a lot!!!
sand fine grid paper 800 or better
primer
sand again 1000 or better
primer
sand again wet 1200
paint 1st coat
dry
paint 2nd
dry
sand 1200 wet
paint 3rd
dry
buffing compound
clear coat
dry
clear coat
dry
buffing compound until smooth and shiney
primer
primer
sand again wet 1200
paint 1st coat
dry
paint 2nd
dry
sand 1200 wet
paint 3rd
dry
buffing compound
clear coat
dry
clear coat
dry
i highly recommend having a experience paint shop to do it.
I am currently prepping my WW urethane kit. I simply skuff the urethane with 120 grit sandpaper, then start spraying layers of primer that I bought from wall mart. After 4 layers or so, I break out the super fine wet sandpaper, and sand all the pieces down so they are nice and smooth. Then I take a tack cloth and go over the pieces, then take it to the shop for painting.
Make sure you have a flex agent added to the paint so it doesn not crack so easily or "spiderweb".
chi@1001
Mar 22, 2002 12:58 AM
