switchblade keys
Old Jan 20, 2006 | 04:01 PM
sony224422's Avatar
Default switchblade keys
can they be made.. like how VW and audis have? I have an extra fob from a 2000 gls but is it possible to cut one of there keys so its like ours?
Old Jan 20, 2006 | 04:20 PM
YeuEmMaiMai's Avatar
Default Re: switchblade keys (sony224422)
no
Old Jan 20, 2006 | 04:27 PM
Diego Dangers.'s Avatar
I've seen some people selling them actually. not from a VW though, but an actual honda key.
Old Jan 20, 2006 | 05:07 PM
Conspiracy's Avatar
Default Re: (Diego Dangers.)
I think you can buy them from your local honda dealership.
Old Jan 20, 2006 | 09:02 PM
sony224422's Avatar
Default Re: (Conspiracy)
can it be cut for like a 96? or only for newer cars.
Old Jan 21, 2006 | 09:05 AM
PhongT12's Avatar
Default Re: (sony224422)
the chip would have to be remanufactured. you can't just cut the key and make it flip since it has a computer chip in every key. i'm not sure about the 1996 model, but they have them for 1998+.
Old Jan 24, 2006 | 05:01 PM
sony224422's Avatar
Default Re: (PhongT12)
does the 96 have a chip in them? i don't think they do because i using a non oem key when i start my car
Old Jan 24, 2006 | 05:34 PM
TouringAccord's Avatar
H-T Order of Merit
I saw someone selling them here on H-T before, or maybe it was another web forum. They only had them in regular keys, not the ones with chips. So you can get them, just have to find them.
I don't believe the 96 models have the chip. If your current key doesn't have a chip, then your car doesn't require it. Just look at you key.
Meangean's Avatar
That would be really cool
Old Jan 24, 2006 | 07:17 PM
sony224422's Avatar
Default Re: (Meangean)
how can i tell if it have a chip in my key
Old Jan 24, 2006 | 09:07 PM
92ehatch's Avatar
it iwll have a chip on it.....thats it.
its in plain sight.
Old Jan 24, 2006 | 09:22 PM
honda starting using the immobilizer in the 1998 model year for the accords
Old Jan 25, 2006 | 12:52 AM
1991AccordLX's Avatar
good question. i've done what you have posted. i've had a spare fob from an Audi. i've searched and found a spare of my honda keys. it's pretty tough to put tha accord key to get it fit. with some welding and shaving off of soem pieces from tha fob, i got it to fit and works fine. i've also tried to get to fit my alarm into that thingie ..but it's too big for tha fob. but i had success replacing my keys into tha spare audi fob i had.
Old Jan 31, 2006 | 12:17 PM
hondacar1993's Avatar
Default Re: switchblade keys (1991AccordLX)
try going to ebay and search honda key i found a switch blade key for a CRX Si
Old Jan 31, 2006 | 04:44 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: (93cb7sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93cb7sedan &raquo;</TD></TR><TR><TD CLASS="quote">it iwll have a chip on it.....thats it.
its in plain sight.</TD></TR></TABLE>
ACTUALLY the chip would be inside of the key not visible like older GM models. Sorry to burst your bubble.
No once and for all this 96 does not have an immobilizer system so no chip in the key
(easy way to tell if it has an immobilizer system is to look for a picture of a green key in the gauge cluster when putting the key in the ignition or while starting it, if the light is flashing that means the key is not programmed.)
Old Jan 31, 2006 | 05:22 PM
sony224422's Avatar
Default Re: (MooGoCow3)
ahh ok. my mothers odyssey has that in it.
but yeah i didnt think a 96 had a chip in it seeing i got a normal key cut haha. thanks though.
Old Jan 31, 2006 | 07:13 PM
Slats's Avatar
One thing you could probably do is to modify your key and keyfob into one unit. The new Accords have the transmitter built right into the key which is kinda cool. For some reason the new Accords have this, but the Acura TSX (euro Accord) does not, so some TSX owners are converting there keys. If you are interested I'll see if I can find the online DIY for this.
Slats
RM022748
Sep 9, 2017 09:43 AM
justagsr
May 2, 2010 11:22 PM
nothing_shocking
May 2, 2010 11:33 AM
Pooby88
Jul 14, 2007 06:56 AM
