91 Accord manual transmission repair
Old Jan 20, 2006 | 03:28 PM
AccordEX1991's Avatar
Default 91 Accord manual transmission repair
I am trying to diagnose the rattling noises in my 5 speed transaxle.
I already removed all the 12mm hex bolts around the bellhousing to tranny parting line.
But I cannot separate the bellhousing from the tranny. I already have a 3/8" gap but still won't separate. In the bottom parting line, there is a magnet and I found a fragment of a ball bearing cage. I know that there must be a broken ball bearing that needs to be replaced.
What else am i missing to get this tranny separated from the bellhousing. Where can I get a diagram showing at least the tranny internal parts. There is no diagram in the Haynes manual.
Thanks for any help.
Old Jan 20, 2006 | 06:33 PM
hondadude's Avatar
Default Re: 91 Accord manual transmission repair (AccordEX1991)
The Best place you could go is a Helms manual, Ebay usually has some for sale; the internal break down is critical to have if you want to rebuild your trans.
But you will probably be able to find a salvage yard unit as cheap as the cost of Parts and labor rebuilding your trans....$70 per bearing adds up quick.
Old Jan 20, 2006 | 06:38 PM
YeuEmMaiMai's Avatar
use an engine brace to support engine
remove drive shafts
place jack upder trans for support
unbolt trans
remove trans
Old Jan 21, 2006 | 04:53 AM
Default Re: 91 Accord manual transmission repair (hondadude)
I got the transaxle split into half already.
The main shaft front ball bearing is shot.
The counter shaft front roller bearing is also shot.
Does anybody have a part number for these bearings?
Thanks.
Old Jan 21, 2006 | 05:25 AM
Here is a pic.
Old Jan 21, 2006 | 06:32 AM
Found the parts.
Bearing is $27.38
Oil seal is $5.55
Still better than getting a used one for $300.
Awesome parts site. http://www.hondaautomotivepart...USING
Thanks.
2point2
May 5, 2007 02:17 PM
RedBullGotWings
Feb 2, 2006 06:40 PM
scottm
Apr 10, 2003 10:50 AM
jdm92accord
Mar 17, 2002 08:03 PM
