Can distributor handle 11,000 RPM??
well A set of titanium rods and the internals balanced to a gnats *** will be fine, Im just wodering if the stock distributor will be ok
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SL_RICK83 »</TD></TR><TR><TD CLASS="quote">well A set of titanium rods and the internals balanced to a gnats *** will be fine, Im just wodering if the stock distributor will be ok</TD></TR></TABLE>
The bottom end will be able to handle it if it's balanced but your forgeting the biggest problem. Rev your engine to 11,000 RPM and you'll float a ******* valve and absolutely shatter your valvetrain.
Why do you want to rev to 11,000 RPM anyways? You really think your car will keep making power that high?
okay maybe i should have said, forget if the engine can handle the revv's, I Just want to know if anyone has any info on the reliability of the stock Distrubitors capabilities to handle the RPM's
FYI: I have cams that have Crazy duration and double titanium valve springs with valves and retainers
LilCivic04
12
Oct 13, 2005 01:29 AM
asiansgoweeee
17
Nov 12, 2004 07:20 PM
BLUE EH3
21
Jan 10, 2004 11:22 PM
